Chevy 5.3 cam swap- things to replace
Old Nov 30, 2009 | 08:30 PM
01SilvyZ71's Avatar
Default Chevy 5.3 cam swap- things to replace
gettin ready to do my first cam swap (yay) on my 2001 silverado 5.3- the engine is untouched and is a right about to roll over 100k miles. my question is what are things that can be easily replaced while have half the engine apart? here's what i have. feel free to add or take away stuff
intake gasket
knock sensors
clean fuel injectors?
head gaskets
timing chain?
timing gear?
ill already be replacing pushrods, valve seals, springs, locks, etc
thanks! alex
Old Dec 1, 2009 | 11:46 AM
CODE4LS1's Avatar
No need to replace intake or head gaskets unless you're pulling the lifters out. At 100K I would replace the whole timing set.
Old Dec 1, 2009 | 12:49 PM
terravast4's Avatar
oil pump while you are there
Old Dec 1, 2009 | 01:24 PM
MPFD's Avatar
11 Second Truck Club
I slide in a 212/218 low lift with zo6 springs and TSP push rods into my 5.3 at 112,000 and didn't change anything else, not even water pump gaskets. Never had a single problem with anything. I pulled the (still running) complete engine at 168,000 (with about 70 bottles put through it) when I did my 6.0, and sold it to a buddy for $600. It's now in his truck, still holds awesome oil pressure (once went 7000 miles on an oil change and only was down a 1/2 quart), not a single leak anywhere he has put 20,000 miles on it and he runs the **** out of it.
Old Dec 1, 2009 | 01:51 PM
01SilvyZ71's Avatar
hmmm im not familar with engines all that well so i figured i'd just post up some things i knew of. didnt know what all would be required to replace the head gaskets.
so sounds like all i should worry about is the whole timing set and maybe the oil pump?
-alex
Old Dec 1, 2009 | 02:01 PM
MPFD's Avatar
If it will make you feel better about it, do it. But seems like people always screw up cam swaps by dicking around with the oil pump. People are always pinching O rings, or what not, or causeing leaks cause the pan has to be dropped to change the oil pump and bottem sprocket. If it was mine I'd use all the stock parts, slide in the cam and be done wit it, unless your going to some radical cam with super stiff springs...
Old Dec 1, 2009 | 02:24 PM
01SilvyZ71's Avatar
thats prob what ill just do then thanks.
and the cam is a isky 210 216 110lsa im usin 7.4 chrome moly pr, ls6 springs, new seals and locks
Old Dec 1, 2009 | 04:09 PM
MPFD's Avatar
good lookin cam, who is gonna tune it?
Old Dec 1, 2009 | 04:11 PM
Im trying to get mine done this weekend if the weather permits. Post a video so we can hear it.
Old Dec 1, 2009 | 04:18 PM
01SilvyZ71's Avatar
its currently just got a blackbear mail order tune so i guess ill go with a data logging tune from his as well. if i knew of a place around here that i trusted to dyno tune it i would do that instead
