Checked out the heads today
Old Oct 30, 2010 | 04:03 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
How about the valve guides, maybe they're too long causing the seal to sit up too high?
Old Oct 30, 2010 | 04:12 PM
  #22
SincalT/A's Avatar
Do both heads use the same shims/or any on the seat?
Old Oct 30, 2010 | 04:30 PM
  #23
2004SSS's Avatar
i just find it odd that such a big company like et would do this . i know in the past there has been long waits for their products.
i pray i dont have these problems once i start doing the shakedown's .
good luck to your future progress drx .
Old Oct 30, 2010 | 05:11 PM
  #24
DrX's Avatar
DrX
The heads were supplied by the builder.
Only the intake spring seats are shimmed(both heads) - you can see a couple in one pic.
You can also see that the shaft mounting bars are spaced with a couple of washers.
Old Oct 30, 2010 | 06:48 PM
  #25
SincalT/A's Avatar
I've never installed shaft mount but, i would want them to sit flat on the mounting bosses.Using a shim at least i hope thats what they used and not washers would compromise the rigidity of the system.I dont know if it makes defference or not jus speculating here.
So all shims used appear to be the same between the two heads.Speaking in terms of thickness and perspective placement.
Old Oct 30, 2010 | 08:17 PM
  #26
DrX's Avatar
DrX
Looks like the spring shims(intake only) are all the same.
Old Oct 30, 2010 | 08:27 PM
  #27
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Shimming the pedestals isnt uncommon, has to be done for proper sweep pattern.
Old Oct 30, 2010 | 08:30 PM
  #28
SincalT/A's Avatar
Well *** me runnin if that isnt a problem stress fractures at the boss.So one heads worse then the other i take it?
Old Oct 30, 2010 | 08:32 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
FWIW, those are nice looking rockers
Old Oct 30, 2010 | 08:52 PM
  #30
DrX's Avatar
DrX
Left side had several destroyed seals. Right side only one destroyed and one loose, but most of them looked like they were no longer fully seated. I don't think I moved them when I pulled the springs because they seemed to be on there pretty good when I did remove them.
Don't know what's right or wrong here, but I do want to ensure that nothing is missed when this engine is redone.
