change lifters?
Old Apr 27, 2009 | 01:19 PM
454navyss's Avatar
i'll buy some probably next week. ls7 lifters and ls2 lifter trays? what rpm can the yellow ls6 springs handle with a tr224?
Old Apr 27, 2009 | 01:43 PM
silver-mod-o's Avatar
Hunt&Fisherator
depends on the lift honestly.... I personally wouldnt run those springs with that cam...
as far as the trays, I dont know the advantage to those... some people drill 3/8" holes in the bottoms of their stockers to aid in oil draining back to the pan.
Old Apr 27, 2009 | 01:54 PM
454navyss's Avatar
lift is .563 on the cam, the springs are supposed to be good to .570 and i know it is pushing it for those springs but a lot of people are using those springs with that cam with no problems
Old Apr 27, 2009 | 01:55 PM
454navyss's Avatar
would these be a better choice?
http://www.sdpc2000.com/product/SDL1...S1Setof16.aspx
Old Apr 27, 2009 | 10:07 PM
454navyss's Avatar
what else should i do when i tear it all apart?
im doing p&p'd, milled 706 heads, tr224 cam, ls2 timing set, ported ls6 oil pump, 8.1 injectors, valve springs (either the yellow ls6s i have or the ones i posted above), ls7 lifters
Old Apr 27, 2009 | 11:19 PM
Hunt&Fisherator
what head gaskets and bolts/studs??
Old Apr 27, 2009 | 11:23 PM
Hunt&Fisherator
and yes, those springs look a lot more suitable for that cam... its going to be hard on the LS6 springs running them at near coil bind or maxed out. get more spring than you absolutely need IMO... I'm running Crane duals with a GT 2-3 cam LOL
Old Apr 28, 2009 | 12:19 AM
454navyss's Avatar
http://www.texas-speed.com/shop/item...id=86&catid=36
Old Apr 28, 2009 | 12:24 AM
454navyss's Avatar
with what im planning on doing can i mill the heads .030 without any ptv problems?
Old Apr 28, 2009 | 08:32 AM
Hunt&Fisherator
I dont see any problems there.... that cam doesnt have a ton of lift.
