Carnage
Old May 20, 2008 | 07:11 AM
stock48's Avatar
9 Second Truck Club
Default Carnage
Hear is a little bit of carnage. I couldn't wait, I had to knock a bigger hole in the oil pan so I could see inside. Just as I suspected, the rods bent untill the point of failure. 4 rods broke completly, and the rest are bent so bad the pistons touch the counter weights I have suspected I was shortining the rods for awhile now. My compression has ben dropping, and trap speeds were down, but no blowby. Also noticed a wierd knocking started up in the last few weeks, but oil pressure, and leakdown were good. The engine is a total loss, Block, heads, crank, are ruined, and the cam is broken in more than one place. This engine stood up to mid 10sec power and well over 700RWHP daily for months. The bearings had virtually no wear, and the crank still looks like chrome where it's not goudged. As you can see from the color of what little is left this engin had no easy life, I worked the **** out of it for years in it's other life towing heavy loads from Co, to Ca.
Old May 20, 2008 | 07:40 AM
krambo's Avatar
Awesome. Complete devistation.
Old May 20, 2008 | 07:51 AM
dewmanshu's Avatar
Moderately Differentiated
Well, I'd disagree with "stood up to mid 10sec power" as a whole, but agree with, "daily for months". It is a testament that these motors can take a licking, but it started to fail the first 10second pass IMO. I only point this out to bring recognition to the fact that if you boost her that hard, the stock components will fail.
On another note...yess AWESOME, fug a bunch of spun bearings or raising the heads, he grenaded that sheet!!!
Old May 20, 2008 | 08:14 AM
CurtD's Avatar
10 Second Truck Club
Well atleast you accomplished your goal...to find the limit of that engine
Can't wait to see what one of your purpose built engines can do .
Didn't i read where you got a 1.45 60' thats awesome.
Old May 20, 2008 | 08:58 AM
Wilde Racing's Avatar
How do I change this text
You don't think the pistons breaking could cause all of that damage?
Old May 20, 2008 | 09:27 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
you don't do anything half-assed do you?
Crap, some of those pieces are unrecognizable. I say weld them together and make a trophy of them!
Old May 20, 2008 | 10:23 AM
2005 Silverado's Avatar
SPAM HUNTER
Time to get the welder out and put it all back together and make a carnage coffee table!!!
Dustin
Old May 20, 2008 | 10:37 AM
how long did the motor last with u pushing it to the limit
Old May 20, 2008 | 10:45 AM
skeet's Avatar
ouch that looks painful !!!!
Old May 20, 2008 | 11:04 AM
BigTex's Avatar
Man, thats awesome! Look at those piston rings, they look like curley fries.
EDIT - I just read your thread in the drag racing section.
Do you know what rpms were you at when it let loose? Did you have a laptop hooked up logging that run? I'd love to see what the logs looked like.
