This can't be normal, can it?
Old Nov 25, 2011 | 04:45 PM
MikeGyver's Avatar
Default This can't be normal, can it?
The truck has been sitting for about a month or five weeks. I am changing valve springs, and when I pulled the passenger side cover, I found all of the rockers lined up, as in the picture. Do LS7 lifters have enough travel to allow this, if the ones that should have the valves open have bled down? Or should they even bleed down, ever? Is this why it sounds like my monkey inside the engine is tapping his little ball-pein hammer at start up? Time for another new valve train?
Old Nov 25, 2011 | 05:44 PM
Daryn's Avatar
Formerly darynC-10/23/10
they basically lost thier prime . once you crank her up they will fill back up and look liek they are supppposed to
Old Nov 25, 2011 | 09:09 PM
nonnieselman's Avatar
You try and turn the crank?
The 6.0 and 5.3 we put a cam in looked like that. Pull the other cover off and see if they are lined up.
Old Nov 25, 2011 | 09:16 PM
MikeGyver's Avatar
Okay.
Old Nov 25, 2011 | 10:43 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Your valve springs are way stronger than the springs in your lifters. Sitting 4-5 weeks with never having any oil pressure, I could definately see that happening.
Old Nov 26, 2011 | 02:06 PM
MikeGyver's Avatar
The driver side looked normal, some valves were open and some were not. I'll crank it over sometime soon to check out the motion on the passenger side.
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Oct 4, 2015 08:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
01silvy
Sep 26, 2015 10:20 PM
TrickTurbo
Sep 23, 2015 08:41 PM
