can't get to oil pump or front seal with front diff in the way...
Old Mar 27, 2009 | 03:24 PM
Stroker2112's Avatar
Default can't get to oil pump or front seal with front diff in the way...
I really need to get into the bottom of my engine to replace the O-ring in my oil pickup tube..has anyone been able to remove their oil pan without removing the front differential?....i have a 2000 Silverado Z71....
Old Aug 28, 2009 | 11:52 PM
lucky77's Avatar
Banned
any-b done this... ?? do you all know if all o-rings are the same? i need to replace mine, but I've seen red/green/ blue o-rings for the pick up tube..
Old Aug 29, 2009 | 12:02 AM
99sierra4x4's Avatar
Well i have a 99 sierra with the 5.3L, i used the Red newer style o-ring, solved my oil pressure problems i was having, when i first did my cam swap i never replaced the stock old blue one that was in there.
And YES you can drop the pan enough to get in there, i did it several times now, although that bolt for the pickup tube is always very annoying to get back in. Just take your time doing it.
Andy
Old Aug 29, 2009 | 09:41 AM
Bluchevypick's Avatar
That's weird cause my oil pump took the green o-ring and yes you can drop the pan enough to get to it but its a PITA.
Old Aug 29, 2009 | 12:14 PM
Mort's Avatar
I have done it as well and it is a long job but can be done.
Check out LS1howto.com for a good general write up on it.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
