camshaft
Old Jul 30, 2006 | 10:49 PM
rk rumbler's Avatar
Default camshaft
i need some help on decieding what kind of cam to get cause i need a cam that will make most of its power in the mid range cause my truck is a 5.3 gmc every day driver and it already haves a straight pipe bullet exhaust, lt's and a aem brute force intake so any body who know about cams help me out
Old Jul 30, 2006 | 10:57 PM
dirt track racer 81's Avatar
need more info on your truck..
Old Jul 31, 2006 | 12:58 AM
use the search feature.
Old Jul 31, 2006 | 06:56 AM
CamKing's Avatar
Fill in the info, and I can help you out.
Bore:
Stroke:
Rod Length:
Comp. Ratio:
Peak HP RPM:
Stall Speed RPM:
Rocker Ratio:
I also need to know what Cyl heads you have and what has been done to them. If they've been ported, I need CFM flow #'s at .300",.400",.500" valve lift.
Old Jul 31, 2006 | 11:10 AM
if its fairly stock with the stock torque converter the comp 212 218 dur .522 .529 lift 114 lsa cam does pretty good
thompson
Dec 27, 2017 06:48 AM
wickedRCSB
Oct 10, 2015 09:29 PM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
sTNT971
Sep 26, 2015 04:22 PM
