Cams in Manual / Auto transmissions
Old Jun 11, 2010 | 08:35 AM
  #21
BlackGMC's Avatar
Resident Retard
Originally Posted by MPFD
Were all three cams tested on the same dyno?
I wouldn't hesitate to go TR220 even in a 4.8, there isn't enough difference there, that you'll notice in driveability.
Well 2 of the three were on the same dyno, the 3rd was on a different dyno...
There are a lot of factors going on at the track that make it not a very good comparison... Very few talk about their crappy times. Those cams are so close that DA could have easily played as much part as the profile.
apparently you don't know me at all, i tell the good and the bad... I know my truck is not that fast but at least I am honest about what each mod did. Do a search for my name in the drag racing section... I probably have more track time posted than all the people in the this thread combined. We used to go all the time probably every other week or every week during the good weather... And yes we monitored the DA everytime we went...
Originally Posted by PathfinderJr
With a 4.8, I'd especially stick with 1-5/8" primaries. You'll keep what semblance of low-end the 4.8 has, even after sliding a cam in.
I have had 1 -5/8 header on my truck when put on headers... honestly the 1 3/4 actually feel better than the 1 5/8
Old Jun 11, 2010 | 09:17 AM
  #22
MPFD's Avatar
11 Second Truck Club
I didn't realize he was speaking of you. But in that case I would argue that lsa made more over all difference in your gains then the slight changes to duration. And I would still recommend a TR220, because Justin will have a easier time throwing him a DD mail order tune without such tight overlap. I also agree with you on 1 3/4 headers.
I agree you report thoroughly, I have read many of your write ups. The Doorman Intake sticks in my mind.
Old Jun 11, 2010 | 09:25 AM
  #23
BlackGMC's Avatar
Resident Retard
you know LSA and duration both come into to play on the overlap of a cam....
Old Jun 11, 2010 | 09:42 AM
  #24
MPFD's Avatar
Yes I agree, but your FTI with 108+2 is alot tighter LSA then the TR220 on a 112. I've have been told that tighter LSA makes for a harder tune, on the idle driveability side of things.
Old Jun 11, 2010 | 10:06 AM
  #25
PathfinderJr's Avatar
The difference is the OP has a manual and most here have an auto. High stall speeds make it easy to brush right on past any and all lack of low-end due to one reason or another. With a stick, it's a little harder unless you ride your clutch hard at every stop-light or have some pretty deep gears. On my truck with the 5-spd, the 2-3 shift sucked donkey ***** due to the gearing and torque curve of the 4.8, and I already have 3.73's. As you well know, in stock trim, the 4.8 really doesn't start to wanna move until you north of 3-3.5k rpm a decent amount.
Maybe I'm just old-school cause I cut my teeth on gen I sbc's instead of getting into all this with gen III and later, but a mostly stock 290 - 310hp, 293 cube engine just screams for 1-5/8"s primaries to keep the exhaust velocities up to make the power band half-way streetable, especially for a stick truck.
Hell, my old '66 truck has a 400hp, 415 lb-ft sbc 350 whose limitation is actually the induction (needs a bigger carb) as opposed to the 1-5/8" headers.
But when it comes down to it, this is America and everybody can do what they want... mostly. So party on, Garth. Any header is gonna be better than stock.
Old Jun 11, 2010 | 11:15 AM
  #26
BlackGMC's Avatar
Resident Retard
I believe your mixing terminology... increased overlap makes idle harder to tune.... LSA is usaed in calculating overlap, but it is only a portion of the equation...
Old Jun 11, 2010 | 11:19 AM
  #27
MPFD's Avatar
So does your cam have more overlap then a TR220 or am I wrong?
Old Jun 11, 2010 | 11:34 AM
  #28
BlackGMC's Avatar
Resident Retard
on what LSA? an easy (but not 100% accurate) way of calculating overlap is (((intake duration + exhaust duration)/4)-LSA) * 2...
For example:
my cam 214/220 @ 108 = +1* overlap
TR220 @ 112 = -4* overlap
TR220 @ 114 = -8* overlap
Now from my understanding the overlap will shift the efficiency of the cam... More postive overlap will make the engine more efficient in the upper rpms and less efficient in the lower, thus the rough idle... This is one of the reasons my HP starts to die off at 6700-6800.... Now the other part of the choosing a cam is the DCR, which no one in the thread has mentioned... my cam has alot more DCR than the TR220 due to the 106 ICL... Decreasing the ICL (or the +2, +4, etc) increases the DCR. although the CR helps increase the DCR, so that also comes into to play.... my DCR is about 8.5-8.6 this is why my cam makes good TQ down low...
Old Jun 11, 2010 | 11:49 AM
  #29
MPFD's Avatar
I understand SCR vs. DCR. My thinking here is that Black bear who is tuning his truck will probably have more experience tuning for the TR220 which is a very popular cam, then trying to dial something like your cam. Your cam was a nice choice for you cause you have the know how to tune for yourself...
Old Jun 11, 2010 | 11:52 AM
  #30
BlackGMC's Avatar
Resident Retard
Just as a quick reference of my past H/C setups and times...
stock heads, XE220 @114+4 ran a best of 8.8 i think.
stock heads, XE222/224 @112+2 ran a best of 8.6 i think.
prc heads, XE222/224 @ 112+2 ran the same as above (yes i know it sucked)
prc heads, FTI 214/220 @ 108+2 ran the times in my sig 8.3
This is just my opinion.... a smaller duration cam with a low LSA and low ICL and decent lift is the best combo... Great TQ down low due to the higher DCR, and higher overlap to keep the HP climbing throughout the RPM range...
