cam for towing 5.3
Old Jan 21, 2008 | 07:30 PM
seadoo's Avatar
Default cam for towing 5.3
I have a 04 ECSB Sierra 5.3, I am slowly beginning to mod it for more power and towing. I am going with a 3" catback, Thorley Tri-Y's, intake, and a cam. seeing how the 5.3 intake sucks for the most part, and the stock cam uses a reverse split profile, I figure GM used the reverse split for a reason. I am considering a custom cam 209/200 on a 114 with cam motion lobe profiles. I figure that should give a really nice torque bump and should hold more over for while till I get the Radix.
what is your opinion on that cam?
Old Jan 21, 2008 | 07:53 PM
Mr. Sandog's Avatar
I did lots of research on a towing cam for my 5.3L Avalanche and went with a 205/212, .540/.540, 114+4, Cam Motion cam. Perfect with a stock converter, no lapse in power, with a solid 12-15 HP gain across the entire powerband.
FYI, GM does not do a reverse split, you must be reading the spec wrong. Some tables list the exhaust duration before the intake duration, so you have to be careful reading the specs.
Oobray
Jun 13, 2022 03:38 AM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
