Cam Swap- need springs?
Old Sep 14, 2008 | 10:34 PM
FreemanBrian12's Avatar
Default Cam Swap- need springs?
If I stick a crane 216/224 with .551/.551 lift in a 6.0 will I need new springs/rockers/pushrods? thanks, BF
ps-just curious, what are the specs on the z06 cam?
Old Sep 14, 2008 | 10:37 PM
dlt76028's Avatar
i would get some ls6 springs and hardened pushrods. no need for new rockers
Old Sep 14, 2008 | 10:50 PM
would i need to do anyhthing to the heads to fit the ls6 or the crane springs? the more expensive springs that crane recommends for this cam are 1.370 OD and the GM ones are 1.290
Old Sep 14, 2008 | 11:14 PM
I just put the patriot duals in my truck for my TR220 cam...
https://www.patriot-performance.com/...&cat=51&page=1
Old Sep 15, 2008 | 06:18 PM
Truckshop's Avatar
if interested i have pushrods and ls6 springs.
Old Sep 16, 2008 | 12:40 PM
leochevy2001's Avatar
can you post the part# for the cam and springs?
i can't seem to find where crane recommends a spring w/ that OD for a 216/224 .551/.551 cam.
here is the part#144832 for the springs that i could find that crane recommended for that size cam.
Old Sep 16, 2008 | 05:12 PM
i got the number from an article on Cranes website http://www.cranecams.com/?show=newsLetters&no=276 (package number 3 in the article) they recommend 144833 which is 1.237 OD 144832 is 1.264 OD but has the same spring pressure
so I guess these are a smaller diameter than what you found recommened
anyone know what stock 317 heads valvespring OD is? and the biggest OD that will fit on the stock head without modification?
ARC
57
Feb 21, 2022 10:54 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
