Cam Specs, 01+02 ZO6 vs LS6
Old Jan 27, 2008 | 11:04 AM
jkwalkercchs's Avatar
depending on which cam u get the 01 u can get away with stock pushrods
Old Jan 27, 2008 | 11:33 AM
parish8's Avatar
single digit dreamer
this is kind of a neat page >> http://www.smokemup.com/tech/ls1.php
Old Jan 28, 2008 | 03:01 AM
jakebdb56's Avatar
Originally Posted by jkwalkercchs
seriously no maybe a 2 rwhp diff but theres pros and cons with both
o1 would have slight more torque
1-2 rwhp isn't noticeable, nor does it make a difference. just because you're stuck with a '01 z06 cam and you wanna sell it doesn't mean you have to be like a used care salesman in every thread that pops up with someone asking about a z06 cam
regarding the pushrods: he needs hardened pushrods no matter what. no need to worry about stock rods working with a '01 cam.
IMO, with the '01 the longer intake duration would benefit from being boosted, if that's the route you're going.
smokemup is always a good goto site for info
how's the porsche coming parish?
Old Jan 28, 2008 | 05:59 AM
parish8's Avatar
selling the porsche. steped up to a bmw 528i. porsche was just too small for me.
Old Jan 28, 2008 | 09:05 AM
jakebdb56's Avatar
ahhh, fancy fancy
that's gonna be a tight fit getting a lsx into that beamer
Old Feb 5, 2008 | 10:05 AM
WJ MARK's Avatar
Ls6 motor came in the z06 corvette, they are one in the same. Im running an 02+ ls6 cam, made 50 more hp. with the turbo. I like it alot!
Old Feb 5, 2008 | 11:01 AM
RandomHero's Avatar
The specs on the 02-03 ls6 cam are quite a bit more agressive. I would definitely say there will be more than a 1-2 rwhp difference.
NO, he doesn't HAVE to have pushrods, but they are strongly recomended. There are plenty of guys who run stock pushrods and even some guys run stock length pushrods with the 02-03 ls6 cam.
The 01 ls6 cam should make power lower in the powerband but not as much up top whereas the 02-03 should make more power, but later in the powerband.
Old Feb 17, 2008 | 03:09 PM
LS6_Silverado's Avatar
Yea but if you run stock pushrods on a 02+ ls6 cam then you will be depriving your self of lift. 02+ Ls6 cam is 19mm base circle and regular gm genIII engines have a 19.7mm cam base circle. .7mm = .028 so if you use stock pushrods or 7.400 pushrods your lift will only be .523/.519 compared to .551/.547. You will basically be down grading you cam to an 01 cam. You need to buy 7.425 pushrods if you want to take full advantage of your cam.
Old Feb 17, 2008 | 03:19 PM
parish8's Avatar
thats not how it works. the lifters have something like .100 of self adjustment built into them. you will go from the center of that space to the edge but it will still be within the .100. you will get full lift but being on the edge of the lifter specs might cause other issues that i dont know about.
Old Feb 17, 2008 | 04:38 PM
philntx's Avatar
Parish, how much HP did you gain when you changed the stock 5.3 cam for the LS6 cam?
