Cam size ?
Old May 24, 2007 | 02:00 AM
blockheadnic's Avatar
10 Second Club
Default Cam size ?
I come across a deal on a new cam patriot springs and timing set for $450 all new. Well the cam is from futural motorsports. its a 230"/232" .595"/.585" 112LSA with all other supporting mods do you think it would run good in a 5.3l
Old May 24, 2007 | 02:37 AM
RandomHero's Avatar
no that's way too big of a cam unless you run like a 4000 converter, which isn't streetable IMO.
Anything bigger than a 228/228 isn't going to be any fun in a 5.3L unless you spend big money on heads and a ls6 intake conversion.
Old May 26, 2007 | 08:17 PM
ss04flores's Avatar
a 224 is the biggest i would go in a 5.3L
Old May 26, 2007 | 08:19 PM
dirt track racer 81's Avatar
hmm id buy it...for my 6.0..thats a little big for a 5.3..stay at the max 226-228
Old May 26, 2007 | 08:57 PM
what if i run with manuel tranny on it ??
Old May 26, 2007 | 09:39 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Buy it and save it for the 408ci you will build one day.
Old May 30, 2007 | 12:47 PM
Mark Johnson's Avatar
Wink
I thought bigger was always better..........
Old Jun 2, 2007 | 06:55 AM
986.0333hp's Avatar
If you want a slug/ king then yes..........
Old Jun 2, 2007 | 08:15 AM
nightrunner's Avatar
Mr. Obvious
not when it comes to cams, that cam in a 5.3 probably wouldnt "come on" (you feel the power gain) till about 4000 or so, but it would rev to well over 7krpm. not a very streetable cam.
the larger the duration the higher the powerband will be - to an extent
i agree, it COULD be used in a 6.0 and would be better suited in a 383 or 402/408 and its WAAAAAY to big for a 5.3
Old Jun 3, 2007 | 08:09 PM
axisT6's Avatar
Dangit boy! It is m-a-n-u-a-l tranny!
