Cam size ?
I come across a deal on a new cam patriot springs and timing set for $450 all new. Well the cam is from futural motorsports. its a 230"/232" .595"/.585" 112LSA with all other supporting mods do you think it would run good in a 5.3l
no that's way too big of a cam unless you run like a 4000 converter, which isn't streetable IMO.
Anything bigger than a 228/228 isn't going to be any fun in a 5.3L unless you spend big money on heads and a ls6 intake conversion.
Originally Posted by 2001c3driver
I thought bigger was always better..........
the larger the duration the higher the powerband will be - to an extent
i agree, it COULD be used in a 6.0 and would be better suited in a 383 or 402/408 and its WAAAAAY to big for a 5.3
a 224 is the biggest i would go in a 5.3L
king then yes..........
