Cam question, install 0 degrees or advanced?
Old Jul 16, 2008 | 04:27 PM
stock48's Avatar
9 Second Truck Club
I would stick it in at 2* and go.
Old Jul 17, 2008 | 11:51 AM
408 Sleeper's Avatar
I double checked the cam card. It is ground on a 113 and says install anywhere between 0-4 degrees advanced.
Old Jul 17, 2008 | 10:50 PM
gracing's Avatar
If you want to install it at any other postion other than 4* advanced or straight up, you will have to buy an adjustable timing chain set. If you have the valve to piston clearance you can run it 4* advanced. You will loose a little on top end but I doubt that you will notice it. If in doubt call the cam manufacture and ask them where that cam will run it's best and install it. especially if you have done anything else to the engine and tranny.
The_W
Oct 28, 2015 09:00 PM
all_individual
Oct 10, 2015 10:09 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
all_individual
Jul 13, 2015 11:01 AM
