cam question
Old Oct 28, 2007 | 01:45 AM
map0711's Avatar
Red face cam question
how much gain will i look at with a 218/228 .550/.550 on 116 or114 lsa over my current set up, i did just order a 3000 stall converter will this cam be in the same range as the converter.
Old Oct 28, 2007 | 07:57 AM
zippy's Avatar
The gain will be very noticable and with that converter you will always be in the powerband.
Old Nov 13, 2007 | 11:59 PM
Jessica's Avatar
Restricted User
drop the LSA on it and you will get closer
Old Nov 17, 2007 | 07:03 PM
02Denali6L's Avatar
your sig says 112 now. The 116 LSA would slow you down but have a stock idle.
Old Nov 17, 2007 | 07:39 PM
map0711's Avatar
yes i already have the cam in i went for the 112, my previous set up was a ls6 cam
Old Nov 20, 2007 | 07:48 AM
OnyxSilveradoSS's Avatar
so how do you like it? the 3000 stall??
Old Nov 20, 2007 | 11:26 AM
Blindmelon's Avatar
How is the cam working? I am thinking about one that size or range.
Old Nov 20, 2007 | 11:37 AM
_black_sunshine_'s Avatar
o yeah you will fill the diff!
Old Nov 25, 2007 | 12:57 PM
map0711's Avatar
i love it, the cam sounds bad ***, ask charlie, we were getting compliments on how good it sounds while he was tunning it, the converter is very streetable, the only problem is that my truck came stock with 19 lbs injectors so i have to upgrade and retune sometime next week
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
