Cam interchange
Old Jun 25, 2007 | 03:39 PM
old motorhead's Avatar
Default Cam interchange
Will an LS2 or LS7 cam work in an '05 5.3L engine? I know the LS6 cam would work, but I don't have access to one of those. I can get a stock LS2 or LS7 cam for little or nothing. Specs on either look to be forced induction friendly.
Old Jun 25, 2007 | 04:28 PM
thunder550's Avatar
High on diesel fumes
I'm almost 100% positive the answer to your questions is no.
The GENIII engines have the cam sensor at the back of the motor and it senses off the reluctor or whatever it's called that is ground into the back of the cam.
The GENIV engines have the cam sensor in the timing cover and it senses off the cam gear. The GENIV cams do not have the reluctor ground into the back of them.
If you were swapping a GENIII cam into a GENIV engine I think it would work, but you can't go backwards.
Old Jun 25, 2007 | 05:04 PM
BlownChevy's Avatar
blownerator
25 Year Member
you are 100% correct.
Old Jun 25, 2007 | 06:19 PM
Ahhhhh shoot. When it sounds too good to be true, it usually is. Guess I'll start looking for an LS6 cam on the cheap.
Old Jun 26, 2007 | 06:31 AM
nighthawk08's Avatar
you can do it, you just have to get all those extra parts...making you spend a bunch of extra money.
Old Jun 26, 2007 | 11:40 AM
Scoggin Dickey's Avatar
Former Vendor
Swap to the new style front cover with the cam sensor in it (as well as the extension harness to make that move) and run an LS2 timing set. Not too difficult, but again, with the extra parts needed to do so....it's not really cost effective.
Old Jun 26, 2007 | 02:03 PM
vanillagorilla's Avatar
At that point you're halfway to an LS2 swap. That might be easier.
Old Jun 26, 2007 | 03:58 PM
Default LS2 cams
Is there a difference between the early (05 06) LS2 cams and the later ones?
Old Jun 27, 2007 | 08:38 AM
Former Vendor
Not to the best of my knowledge! The difference you're likely thinking of is the crank reluctor wheel....it changed from 24x to a 58x wheel right in there!
lawhitediamante
Aug 12, 2015 12:14 PM
mrhino
Aug 7, 2015 10:01 AM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
