cam installed
Old Jun 26, 2014 | 09:52 AM
turboal1's Avatar
Default cam installed
I installed a Comp cam, 210/224 .556/.568 114 C/L 1500-6600rpm
w/cam kit. had it dyno tuned on reg gas, not good, going to have it
retuned on 93 oct. and a cooler day
Old Jun 27, 2014 | 09:42 AM
1ownerCHEVY's Avatar
This went into Colorado in sig?
Old Jul 2, 2014 | 01:16 PM
turboal1's Avatar
Default cam
yes it went in my Colly, LH9 W/799 Heads from factory
TBSS style int. VVT . no AFM or DOD
Old Jul 2, 2014 | 01:35 PM
gamble686's Avatar
Wow 40rwhp on a mild 87oct tune is a very nice pickup for such a small cam. I bet with some 93 and a more agressive tune you can hit 50rwhp gains from a small cam only. Pretty cool for a baby cam.
Old Jul 2, 2014 | 01:58 PM
turboal1's Avatar
Default cam
we have trucks getting the same HP with out the cam.
i really expected more as per Comp Cam's tech guy.
is this really a small cam for a DD and tow vehicle ?
I wanted to use the stock conv, i also do a lot of long
distance driving on the Tpk at 70-75mph
Old Jul 6, 2014 | 10:11 AM
turboal1's Avatar
Default cam
Bump for more opinions
Old Jul 6, 2014 | 10:56 AM
03sierraslt's Avatar
What kinda timing numbers are you seeing at WO?
Old Jul 7, 2014 | 12:40 AM
gamble686's Avatar
285rwhp on a stock cam? In a 5.3? That would be a extremely healthy Bolton 5.3. I assumed the baseline of gaining 40hp was pretty good. That would be considered a mild cam with odd specs in most every circle. Even in a DD. I would suggest something with more intake duration and less exhaust duration. That wide split duration doesn't make much sense to me. 216/220 or similar specs would work great in your setup IMO.
Old Jul 7, 2014 | 01:16 AM
jmgak47's Avatar
I agree the wide split does not make any sense even with the 799 heads. But being that style head it will respond better to a split then 862 or 706 heads. But no more split then 10 degrees should be needed unless you are running stock manifolds and using it for a band aide.
Would respond well to a ProCharger though...
Old Jul 7, 2014 | 08:44 PM
turboal1's Avatar
I forgot to say it's a VVT cam
