Cam Help
Old Aug 19, 2005 | 08:33 PM
99Silver6.0's Avatar
Originally Posted by moregrip
I'm pretty sure with an XER lobe you'll want to stay with the stock rocker ratio.
Quite a few people including Thunder recommends you do not use higher ratio rockers with their(XER) cams.
Old Aug 19, 2005 | 08:55 PM
02sierraz71_5.3's Avatar
all that lift is wasted without head work, even just the lift on the cam is a little big for stock heads. Then you have to think about dual springs and changing them plus they are alot harder on lifters pushrods etc..
Old Aug 21, 2005 | 04:13 PM
ONLYA4.8L's Avatar
So what you think would be a good cam? Its my daily driver but I only use it to go back and for to work. I want to get a good cam that will give me alot of power that I can use with a 2800 stall and stock heads, any ideas?
Old Aug 26, 2005 | 12:32 AM
vanillagorilla's Avatar
TR224 or the Lunati equivalent. The comp 222/224 cam does pretty well too in 4.8's. Remember you can get a custom cam from Comp if you want to. I have a 219/228-112 in my 4.8 with a 3000stall. It too is my DD, and I wouldn't go any more than 228 on duration. It lopes pretty hard, and you're going to need a damn good tune to make it easy and fun to drive on the street....everyday. Also the 112LSA doesn't help either. The comp/TR lobes are ground with fast ramp rates that don't require the use of higher ratio rockers. In fact the lift that was quoted earlier would probably require a spring that would reak havoc on a factory hyd. lifter.
Oh yeah, welcome to the forum fellow Zoner!
Also check out the cam thread:
https://www.performancetrucks.net/fo...d.php?t=235563
Old Aug 26, 2005 | 07:57 AM
Rhino79's Avatar
9 Second Club
2800 converter defenitly not enough, need 3000-3500 and I wouldn't go with 1.8 or 1.85 rockers with that cam.
Old Aug 26, 2005 | 08:24 PM
ONLYA4.8L's Avatar
Thanks alot.. Hopefully my truck will run like a beast.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
