Cam guys here please advice for my 2002 4.8
Just looking to see what cam you guys would recommend. it a 2002 GMC Sierra 4.8 auto regular cab truck . I t is my daily driver and I will tow my hot rod with it on occasion. I am looking for a nice lobby sounding cam at idle. let me know what you recommend thanks in advance.
Converter will play a big roll in what cam you get or what you can tow... If your not big on sticking a big converter in a 212-218 comp would be nice on a 112+2( might have to have that custom ground) Do a search, this ?? gets asked a million times..
I don't really know what cam is going to give you some lope, increase low end, and work well towing in a 4.8. Power wise you could do like Mangled metioned and go with a small grind, but I don't know how it would work towing. Most cams in a 4.8 are going to need a looser converter.
My Yank has been flawless for over 2 years most of the brands guys run on here, YANK- CIRCLE D - VIG( the big 3) are all good, have a great track rec.. You need to decide what your comfy with in terms of stall speed... The z o6 cam would be great if your boosting it, but there is other choices that will be better suited..
remember though that if you wanna run a decent size cam in any auto that you are gonna typically need more stall in a truck bc it is alot heavier than a car. big stalls and deeper gears gets theses heavy pigs moving out.
lxcoupe
Jul 21, 2015 02:12 AM
Suburban2500
Jul 19, 2015 04:50 PM
bsgiffor
Jul 19, 2015 11:14 AM
