Cam difference LS1, LS2
Old Apr 30, 2010 | 05:59 PM
03sierraslt's Avatar
Default Cam difference LS1, LS2
What all needs to be done to run a GenIII cam in a LS2? I know the LS2 is a single bolt cam but is there anything else? Is it as simple as a cam and timing gear swap?
Old Apr 30, 2010 | 06:02 PM
1Bear's Avatar
Basically yes, you've got it. The Gen IV in III is where the issues start arising, but even then it's possible.
Old Apr 30, 2010 | 07:38 PM
Preston129's Avatar
Should change the chain tensioner to the black wedge style too; I've read it's better for harmonics if you're running a 3 bolt cam/gear.
Old Apr 30, 2010 | 09:09 PM
acethedragon's Avatar
the ls2 is a 3 bolt cam too. the changes are in the ls2 cams sensor is in the front cover. would have to put in an old style that reads off the back of the cam for gen 3. not sure if the ls2 block has a provision for that. might not have to change anything but the cam and springs. sensor would still read off the cam gear. gen 4 didnt go to single bolt cams til bout 07 or 08. not sure exactly when.
Old May 1, 2010 | 04:28 AM
This is a 08
Denali08
Aug 9, 2015 04:34 PM
jaypowe11520
Jul 29, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Black-Syde
Jul 6, 2015 02:12 PM
caviness
Jul 5, 2015 10:49 PM
