which cam is a better performer for my setup
They are both from thunder racing THE OLD MAN CAM and THE CHEATER cam which would be a better performer for my set up your guys info would help me out alot cause i am in the process of purchasing one thanks
specs are as follows
OLD MAN- 214/220 .600/.523 115+2 lsa- stock power band off idle-6100rpm
CHEATER- 214/230 .601/.570 117 lsa- off idle-6800rpm power band
goals are to be in the 12.9-13.2 1/4 range please let me know cause i am in the process of purchasing a cam
Are you planning to spin the engine to 6800 to use the power band of the Cheater cam? If youre going to stay at 6200 or less I think the Cheater cam would be trading power down low for power you're not gonna use on top.
I'm not the most knowledgeable on cams but I see a 3000 stall in your sig so I think I would go with the bigger Cheater cam. Spinning it all the way up to 6800 is gonna be awesome with that stall. I'm sure more will chime in soon...
