Cam ?
Old Dec 5, 2011 | 10:34 AM
  #21
Black08Chevy's Avatar
Whats the specs on it?
Old Dec 5, 2011 | 11:22 AM
  #22
cammed5.3 210's Avatar
Intake Duration: 224 Degrees at .050" Tappet Lift.
Intake Lift: .609" with 1.7 rockers.
Exhaust Duration 230 Degrees at .050" Tappet Lift
Exhaust Lift .607" with 1.7 rockers.
111 Degree LSA
Old Dec 5, 2011 | 12:15 PM
  #23
with that cam you need a 3600-4k stall. that cam would love a 4k
Old Dec 5, 2011 | 03:53 PM
  #24
Out of the 220/220,551,551,112 and the 220/224,581,581,112 can u feel a difference on wot
Old Dec 5, 2011 | 05:14 PM
  #25
Not a lot but the 220/224 will pull harder in higher rpms
Old Dec 5, 2011 | 05:40 PM
  #26
Like from wat rpm to wat will it pull harder
Old Dec 5, 2011 | 05:44 PM
  #27
it should pull up to 6400-6500 rpms but wont be a big difference from the 220/220 just a little stronger.
Old Dec 5, 2011 | 06:08 PM
  #28
Cuz now I have the 220/220,551,551,112 cam installed on the truck but i am askin opinions to c if i stay with that cam or swap it to the new 220/224,581,581,112 cam
Old Dec 5, 2011 | 06:37 PM
  #29
Depends on your plans on build. Id do the 220/224, 224/230, or 224/228. Something with a split will perform better if youre doing after market heads or going FI.
Old Dec 5, 2011 | 06:45 PM
  #30
Wat does fi stand for
