Cam ?
Old Dec 4, 2011 | 03:51 PM
dmelvin's Avatar
The 112 LSA will move the power band back down in the RPM band a bit, so that will counteract the bit larger duration. It should have a fairly choppy idle as well. What springs were you planning on running with it?
Old Dec 4, 2011 | 04:16 PM
cammed5.3 210's Avatar
Which cam is better 220/220 551,551 112 or the 220/224 581,581,112
Old Dec 4, 2011 | 09:00 PM
Jake99's Avatar
220-220 will pull better form idle to 4500-5000 rpm, the 220-224 will make more power after that, so its pretty much what ever you want more. both will work real well.
Old Dec 4, 2011 | 09:08 PM
Which cam will work better on top end
Old Dec 4, 2011 | 09:11 PM
Black08Chevy's Avatar
220/224 will pull a little more and with a 3600-4k stall will be a beast. I run a 224/230 with a 3600 stall and it runs very strong.
Old Dec 4, 2011 | 09:45 PM
I have a 3200 stall would that work for the 220/224 cam
Old Dec 4, 2011 | 09:48 PM
yea it would be a great stall, but like all mods theres always better.
Old Dec 5, 2011 | 06:31 AM
If I was to get the 220/224 cam at wat rpm and wat mph will I feel it start pullin
Old Dec 5, 2011 | 09:27 AM
it will start pulling good around 3600 rpms
Old Dec 5, 2011 | 10:13 AM
The Eps cam would it work on my truck
