cam in a 03 5.3???
Old Feb 13, 2008 | 07:50 PM
Lowered 93Z's Avatar
Default cam in a 03 5.3???
ok guys i have a sleeper GM performance cam out of a vett the specs are
.550 lift 218 intake and 204 exhaust with a 117.5 lsa i want to put this in my silverdo 5.3. I have done cams in nurmous cars but this is my first truck, my big question is about the push rods will i need to shorten them? Oh i already have the springs thanks
Old Feb 13, 2008 | 08:28 PM
truckmann's Avatar
It depends on the base circle size of the cam.
Old Feb 13, 2008 | 09:03 PM
07redchevy's Avatar
i would go with the 220 cam
Old Feb 13, 2008 | 09:08 PM
00ChevyScott's Avatar
Wearin' da big hat
he didnt ask what cam to go with... he already has an LS6 cam.
Old Feb 13, 2008 | 10:05 PM
i will get back on the gm site and see if i can find it i will be out of town for the next 2 days. what kind of power do you guys think i will get out of this cam with a tune
Old Feb 13, 2008 | 10:33 PM
I got the TSP 224R cam and it uses stock length pushrods! That cam should be the same as well!
Old Feb 14, 2008 | 05:29 AM
thats what i am hoping
Old Feb 14, 2008 | 02:50 PM
optikalilution's Avatar
i have the same cam, i will be using stock length pushrods when i get the info on how to install it and some free time
Old Feb 15, 2008 | 08:17 PM
sweet that cam swap is about as easy as it gets. i have done a few ls1 camaros this should be a cake walk compared to the cars
Old Feb 15, 2008 | 08:30 PM
gmcdealertech's Avatar
Thats an LS6 cam. The LS6 runs heads with longer hollow stem valves due to the .550 lift that cam has. You should be running 7.425 pushrods to accomadate for the smaller base circle of that cam since you'll be running heads with shorter valves.
