Calculating cylinder fill
Old Oct 21, 2006 | 11:23 PM
02sierraz71_5.3's Avatar
Default Calculating cylinder fill
How can I tell when the cylinder is full based on basic info like head flow #, cam, intake, rpm.
Trying to spec out a cam for optimum area under the curve (DCR will be 8.6-9.0). The motor is a 6.0 ls6 intake, afr 205 heads (SCR=11.25:1), pace setter headers, full exhaust.
Old Oct 21, 2006 | 11:42 PM
dewmanshu's Avatar
Moderately Differentiated
need to get your hands on the dyno sim software. Good ****.
btw, no idea, can't help ya. LOL
Old Oct 22, 2006 | 01:44 AM
any reccomendations?
Old Oct 22, 2006 | 08:39 AM
Sport Side's Avatar
Flow @ 28" = (CID * RPM * .000978474) / Number of Cylinders
X = (364 * 6500 * .000978474) / 8
X = 289.4 (cfm)
RPM Range = (Cylinder Head Flow@ 28" * Cylinders * 1022) / CID
X = (289.4 * 8 * 1022) / 364
X = 6500
Just some **** I dug up. You can see that if you take a head like what AFR provides, the cam can get really small to get you that very high avg. tq. Good heads require less cam for a desired rpm range. If you want lots of rpm then get bigger on the cam also, but if you wanted that you wouldn't have chosen the 205s. Maybe some ETP 265s. LOL
Finding the ideal cam is going to come up to knowing what to do with the valve events. Best to find a valve event calculator and a bunch of dyno graphs and find trends. See what 4* of advance does to the shape of your torque curve. What does a wide LSA do in these motors? How much exhaust lobe is requires for 6500 rpm? The pros know these answers the best and its mainly due to experience and much less of formulas.
Old Oct 22, 2006 | 10:45 PM
This is what Ive come up with so far for high VE's early in the rpm but DCR is 9.42511739822109 Id like to keep the Ve's up but I dont see that DCR happening with 93 octane
Tydriver
45
Oct 23, 2015 09:19 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
dantheman1540
Sep 15, 2015 08:28 PM
MA$TER_E
Sep 9, 2015 03:14 PM
