BTR Stage 4 truck cam 5.3l vortec
Old 12-13-2017, 08:06 AM
madmann26's Avatar
Originally Posted by papa_roach_scars.mp4
Ok, that is what I had thought, I am leaning more towards the BTR Stage 3 since it is a daily. Would you have any cam suggestions that would make similar power figures with a more streetable setup? Personally would prefer quite a bit of lope so maybe something with a little less overlap than the BTR Stage 4? Should be mentioned I am not the best mechanic as I'm still learning.
Overlap = lope/chop
LSA = some chop but moves the power in earlier.
Take for instance, my new cam, has 11.5 degrees of overlap and lopes really good. It's on a 110lsa
My prior cam, had -1 degree of overlap, had a little chop but was on a 115lsa and would pull to the moon.
I'm realistic and I think the 110lsa cam will better suit me for DD.
The following 2 users liked this post by madmann26:
Killerado (01-19-2020), papa_roach_scars.mp4 (12-13-2017)
Old 12-13-2017, 08:39 AM
BlackPanther6.0's Avatar
for daily i would recommend the Stage 2 and it will have a slight chop to it. ive had it in my 5.3 and now in my 6.0 and its a torque cam for sure, and it pulls good up top.
Old 12-13-2017, 10:57 AM
Registered User
papa_roach_scars.mp4's Avatar
The 110lsa is intriguing, I am thinking about running a 2800 stall converter from a Trail Blazer. Would you say the BTR Stage 2 or 3 versus the 110lsa for driveability, performance, and price. My truck is a mostly stock, as in 245/75R16 tires with lighter wheels than stock. I'm going to get long tubes and a cold air intake in the future.
Old 12-13-2017, 10:58 AM
Truck Sponsor
RPMSpeed Tech's Avatar
For a 5.3l daily we would recommend the TSP STG3 high lift cam. Cut it on a 111 amd youll have a nice lope at idle. That's the largest youre gonna get without losing the bottom end and starting to need a stall. The higher lift promotes more power and extends the powerband with no drawbacks! Super quiet lobes and easy on the valvetrain. Use a pac1218 and get the whole kit with springs pushrods and cam for $575.
If you are looking at lifters, our prices cant be beat on lifters and install kits.
Let me know if you wanna go that way!
Old 12-13-2017, 11:21 AM
1slow99's Avatar
btr stage 3, with a stall, and some 4.10 gears, if stock 212/218 cam for sure.
Old 12-13-2017, 11:43 AM
Registered User
RPMSpeed Tech, that sounds like quite a good deal. I was concerned about buying a cam, springs, and pushrods only to see they don't work with each other. How do you think the lope would be with long tubes and open Y-pipe? Also, any estimation on the power and torque gains I would see?
Old 12-13-2017, 11:59 AM
Truck Sponsor
lope will depend on tune really. allow more timing difference itll lope more. itll have a nice rolling lope
Here is a link to cam and dyno graph.
Old 12-13-2017, 12:36 PM
Registered User
I couldn't really hear how it sounded in the dyno although I like how the numbers look. I was thinking around 450 hp would be adequate and pull pretty good. I like where the torque is but I'll probably mess with the tune to make the throttle response quicker.
Old 12-16-2017, 11:01 PM
brandon6.0's Avatar
Dont get caught up on the lsa of diff cams for choppiness. Its all in the tuning. Like i said before i can make a 114 chop hard. A 111 will be a serious chop.
Old 12-17-2017, 12:17 PM
Truck Sponsor
Intentionally making the timing low at idle doesnt help with smell or efficiency though or making the idle rpm intentionally low.
Usually 4* of negative overlap is about the limit on a lopey idle unless you have full exhaust which acts like a tuning fork then. Our high lift hot cam is on a 112 lsa and has -1* of overlap and it sounds pretty good in an ls1. (
) Put it in a 5.3l it would sound more aggressive at idle and be pretty close to what you would want in an all around truck cam. Early power with strong torque.
