Crankshaft pulley
Old 05-28-2018, 06:10 PM
Sierraman02's Avatar
Default Crankshaft pulley
i am having a very hard time getting my crank shaft pulley bolt off I have a breaker bar and a 2 foot pipe and it still won’t come off should I try heat next?
Old 05-28-2018, 06:16 PM
03sierraslt's Avatar
Impact gun.
Old 05-28-2018, 06:23 PM
Do not have a larger impact then what I have tried
Old 05-28-2018, 06:27 PM
FFDP's Avatar
You can heat the bolt up and hope the heat transfer good into the crank. Don't go crazy round the pulley because you'll melt the front cover oil seal.
Old 05-28-2018, 06:52 PM
Any better ideas then heating it up?
Old 05-28-2018, 07:06 PM
FFDP's Avatar
A longer pipe or a stronger impact is about all I got for ya.
Old 05-28-2018, 08:37 PM
suppose I could buy a air impact
Old 05-28-2018, 08:41 PM
100% Redneck
RedXray's Avatar
Received 1,329 Likes on 792 Posts
Just buy a cheap torch from Lowes or Home Depot. Used a torch and impact to remove mine. Then used an Autozone free rental (Chrysler type) balancer tool.
Old 06-19-2018, 12:21 PM
Drspencer's Avatar
I got a Snap On MG725 about 7 years ago off eBay for $100. Check eBay and Craigslist for used tools. Also, your fittings may be restricting airflow. Check out Milton high flow fittings. Night and day difference.
Quick Reply: Crankshaft pulley
