Blower cams !!!
Old Jul 6, 2011 | 05:25 PM
  #71
swift700's Avatar
Bigger cam and bigger converter will improve top end speed. To really maximize the cam, bigger heads will help, too. The converter will cover the launch and the reduced bottom end power.
Just read your post on your cam purchase. Sounds like a good one, that's lots of lift. The OD pulley will really help. I had 9 lbs on my mainly stock 5.3. With the OD pulley I have 9 lbs again but now it's on my 6.3 with big heads and cam.
Old Jul 6, 2011 | 06:18 PM
  #72
TIM Z's Avatar
11 sec. Truck Mod
Sweet, so you like your OD balancer huh? I think i might lose a # of boost with this cam change, so if the balance adds 2-3 psi i hope i gain an honest 2 #'s at least, I really want to see about 11.5-12 psi.
Do you know how much boost the OD helped on your combo?
This cam will help my low end a bunch im told, my MPH is good showing i have good horsepower, but my heavy truck is lacking bottom end with the current cam, so we will see what the new cam does.
Headwork if i do it will be a winter project, im happy with my stall, but i have a free restall down the road if i need it
Old Jul 6, 2011 | 06:22 PM
  #73
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by lt1s10
Just got my heads back from the CNC today- looking forward to how the cam works for you. What happened to the street vids you promised??
Cool deal man! Bet those heads will work good for ya, lemme know.
Vids will come, ive left plenty of rubber around here with no one to record!
I need a go pro camera.
Old Jul 6, 2011 | 07:27 PM
  #74
swift700's Avatar
Not sure what it would have been without the balancer. I'm guessing around 6.5 or so. I hoped for 9psi with this combo and that's exactly what I got. Remember, this is at 4500ft elevation so at sea level I'd see another inch or so.
Old Jul 7, 2011 | 01:39 AM
  #75
AKlowriderZ71's Avatar
11 Second Hall Moniter
I doubt it. With no other changes made, I'd bet you gain boost(1-2 psi).
Waiting for results.....
Old Jul 7, 2011 | 02:39 AM
  #76
TIM Z's Avatar
11 sec. Truck Mod
That would be cool with me, we will see!
Old Jul 7, 2011 | 06:23 AM
  #77
budhayes3's Avatar
PT's Slowest Truck
219 -231 113.5 LSA .607 .614 Lift comp custom grind spec'd by T J @ Baker engineering.
Should work well with my setup.
Will have it this week , as well as an Innovators West OD crank pulley.
Im thinking the cam and 2-3#'s more boost will get me to where i want to be.
I like those specs for your setup, I bet that it'll work great! I'd definitely have some plans for heads in my future to take full advantage of the .6xx lift of that cam, especially with the boost.
I recently read an article that explained how important a good set of heads are, and that the old theory of "no need for heads, the boost will take care of it" really is incorrect, and good flowing heads that would be considered for NA applications also apply to boosted apps (with less compression when necessary of course )
Old Jul 12, 2011 | 08:18 PM
  #78
TIM Z's Avatar
11 sec. Truck Mod
Thanks Billy! I 'd love to do the heads, but not till winter atleast.
Heres My Helper( 3 yr old Wyatt) with my new parts that arrived, ( You'll appreciate this Billy, having yourself a special helper also.)
My Cam arrived today,( THANKS T J @ B.E.I.!) also Thanks to my bud 03sierraSLT For the crank balancer install tool! Ive used it before and it works great!
Also have my IW od pulley ready to install, im gonna do it all at once.
And a boring pic of the 6.0, i had to put a new knock sensor harness on, thats why i pulled the blower. She needs a lil clean up and paint while im there.
Prob wont be till this weekend i get it installed, then gotta see T J for a final retune!
Old Jul 13, 2011 | 03:24 PM
  #79
budhayes3's Avatar
PT's Slowest Truck
Nice looking pile of parts, gotta admit that I've got a chubby!
Great little helper too, he looks right at home in the "garage" You are totally correct, I can totally appreciate having a little helper
Old Jul 13, 2011 | 09:56 PM
  #80
1989k1500's Avatar
I first saw the pics and I thought damn he pulled the supercharger off just to swap cams, must like extra work. lol
