Block advice for high power build
Old Dec 15, 2011 | 11:32 AM
exodus's Avatar
Question Block advice for high power build
I am getting into my first serious power build and I have been trying to decide if the LSX block or the RHS block is the way to go. I know they are both 6 bolt head and I understand that the RHS is costly. My question is this... For a 402-416 C.I. motor that will see forced air from an F2 Procharger or even possibly twin D1's is there anything about these 2 that is either pro's or cons that is not listed in the basic info of each block? I want the bottom end strong, but I am not too sure which of these is the better of the 2 for this application. Does anyone have a 800-1200 FWHP vehicle using one of these 2 blocks? Any other links to info I might have missed? Any info or advice here would be a great help as I really want to not have to learn the hard way. Thanks in advance.
Chris
Old Dec 15, 2011 | 01:30 PM
02'Z71ONDUBZ''s Avatar
I don't have any personal experience these but I think you could easily reach your goals on either block. That LSX block is built to hold serious power. If you are not assembling this engine yourself I would let your builder choose the block. Personally, I would just have HKE or Virginia Speed build you a boost motor to meet your goals and not worry about it.
Old Dec 15, 2011 | 07:02 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
For your power goals, and CI, stick with an iron 6.0 block (i'd do 408 or 402, and forget the 416).
Old Dec 15, 2011 | 07:10 PM
scooter k's Avatar
I just talked to TSP and they said an Iron Block 408 with good parts would easily put down 1000 rwhp with Forced induction. Block would be the weak link though.
ARC
57
Feb 21, 2022 10:54 AM
USMCvet0311
Aug 14, 2015 10:28 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
slowlsx
Jul 13, 2015 04:18 AM
