biggest cam?
you could do a 232/238 109 if all you care about is how it sounds.
There's probably 200-300 cam threads right now asking the same thing so without reading any of them i'd suggest a 214/218 112
There was a guy on here running a Comp Thumpr cam in his 4.8, wasn't fast at all I don't think but sounded nasty. I run a 221/221 .558 112 lsa in mine and it sounds good, under geared and under stalled but it runs ok.
Clearance would be determined by lift, not duration. You'll want to get LS6 valve springs for anything up to a .580 lift and aftermarket cams have a smaller journal so you need 7.4 hardened pushrods
