Best Rings for 6.0 with nitrous
Old Oct 21, 2016 | 10:57 AM
legerwn's Avatar
Default Best Rings for 6.0 with nitrous
Buddy of mine is rebuilding his 6.0 and was wondering what rings everyone is using.
Pretty much stock internals with Lunati cam in the area of 221/218 and head work. Made a little over 400 at the wheels.
Neal
Old Oct 21, 2016 | 04:20 PM
FFDP's Avatar
I don't see any reason why stock piston rings couldn't do the job.
People run 700+ whp with stock bottom ends so I'd think they'd be just fine.
Old Oct 21, 2016 | 04:49 PM
legerwn's Avatar
Apriciate it FFDP
Old Oct 22, 2016 | 08:40 AM
3500Silverado's Avatar
Total Seal coated tool steel.
Old Oct 22, 2016 | 09:47 AM
legerwn's Avatar
Appreciate it 3500
Old Oct 23, 2016 | 08:16 PM
MrHorsepowerLSx's Avatar
11 Second Club
I run total seals in my LQ9 as well
Old Oct 24, 2016 | 07:57 AM
legerwn's Avatar
Thanks for your input MrHP
Old Oct 25, 2016 | 08:31 AM
Aaron at SDPC's Avatar
Former Vendor
Total Seal makes a nice ring set, but in reality I've seen the factory rings take some pretty good abuse and hold up fine. If everything is apart you might consider opening the ring gaps up for use with a big power adder.
Old Oct 26, 2016 | 04:12 PM
legerwn's Avatar
Aaron, how much do you recommend opening them up? This motor dyno'ed a little over 400 HP (RWHP) with tuning and he is working his way up to a 300 HP shot.
Neal
Old Oct 27, 2016 | 08:43 AM
Notalent's Avatar
Totalseal CS AP ring package if your going to be replacing rings, cheap insurance. They are a bit more forgiving on the cylinders than say a Hellfire. For gap, follow Totalseals spec chart and you will be fine.
Nitrous 150HP-350HP Gas, Alky, E85 Bore X .0075" Bore x .0065" Min .015"
