Belt chirp. Any Ideas?
Old Feb 24, 2013 | 04:24 PM
Camin00's Avatar
Default Belt chirp. Any Ideas?
I put a ASP underdrive pulley and alternator overdrive pulley on 30Kish miles ago. I re used the stock bolt not knowing it was tq to yield at the time.
It ran fine for 10Kish miles then a real bad sqeak/squeal started. I figured it was the bolt coming loose, so I took the stock bolt out cleaned it and the crank threads locktited and impacted the hell out of that thing. No issues till recently.
About 1000 miles ago a chirp started happening when it was cold. I figured it was the bolt again so I bought the ARP crank bolt.
I put it on this weekend cranked it down to tq specs and put a new belt on.
STILL A F****** Chirp till the truck warms up then no chirp till the next cold start
Old Feb 24, 2013 | 04:36 PM
03sierraslt's Avatar
Spray a little water on the belt one side at a time to see what side is making noise.
Make sure your power steering pulley is seated properly, I know you didnt replace it but I have seen a couple recently start to walk off.
Old Feb 24, 2013 | 04:40 PM
terravast4's Avatar
I had a similar problem and it ended up being the belt tensioner
Old Feb 24, 2013 | 07:01 PM
Camin00's Avatar
I tried to tighten the power steering pulley. It would start to spin the motor, so I held the power steering pulley with one hand and tightened with the other. no turn of the alen head bolt. does this mean the power steering pulley is on all the way, or has not walked?
I havent checked the tensioner. They are $20ish I might go buy a new one tomorrow.
Old Feb 24, 2013 | 07:03 PM
Camin00's Avatar
I rubbed soap on the grove side and it would stop chirping for a 2-3 seconds then start chirping again, so this means it is a grove pulley correct?
Old Feb 24, 2013 | 07:07 PM
I said water because soap tends to screw up the belt in the long run, but yes. As for the power steering pulley, it is pressed on so I am not sure what you mean about the hex head? The pump shaft should be flush with the end on a stock setup. Can you post up some pictures of what you mean?
Old Feb 25, 2013 | 01:04 PM
Camin00's Avatar
By hex head I ment the bolt on the front of the power steering pulley. It is an Allen wrench bolt.
I will take some picture later today and post them.
Do you have any pics of the power steering pulley correctly in place and walked forward?
Old Feb 25, 2013 | 02:18 PM
My power steering pulley didn't have a bolt.
The pump shaft should be flush with the end of the pulley snout.
Old Feb 25, 2013 | 02:42 PM
trevorh1's Avatar
the power steering pumo pulley doesnt have a bold that holds it on, its press fit it takes a special tool to remove and install it. ive seen more than a few pulleys that were not on all the way just like 03sierraslt said.
madmann26
Apr 29, 2020 09:17 AM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Cammed4ever
Sep 30, 2015 03:38 PM
murderedSS
Sep 27, 2015 10:16 PM
