before i turn into a stand is this salvageable
Old Oct 27, 2018 | 07:27 PM
bluebommer07's Avatar
Default before i turn into a stand is this salvageable
have had this block for months and never noticed that piece of the lifters bore was broken off. my question is can this broken piece be built back up and either honed or re-sleeved to save this engine. block is and aluminum 6.2L this is the only defect on the block, i have heard of it being done but not sure on this one being that is is a clean break
Old Oct 27, 2018 | 08:06 PM
skolman91's Avatar
After zooming in id be more worried about the grooves in the bore surface than the broken piece. Lifter bores can be sleeved im pretty sure by a competent machine shop.
Old Oct 27, 2018 | 08:21 PM
i was worried about that also but if i can resleeve then a shop can do something with that groove its not all the way just the section you see and top of bore
Old Oct 28, 2018 | 10:47 AM
1FastBrick's Avatar
Custm2500's Rude Friend
As I mentioned on the tech side. They should be able to weld it up and worse case they could bush the bore if needed.
Old Oct 29, 2018 | 12:47 PM
cool all you have given me hope. Worst case I would boost the 4.8 i have in the truck.
Old Oct 29, 2018 | 12:53 PM
1FastBrick's Avatar
Good! hopefully there is a shop by you that can do the work.
Old Nov 20, 2018 | 03:52 PM
Burnett03's Avatar
The 4.8 is a very stout engine that can take a lot of abuse. The 4.8 is not a "worst case" option
53bowtie
Apr 2, 2013 12:07 PM
03 Silverado - Son!
Mar 29, 2013 11:38 AM
street demon2k3
Apr 19, 2007 08:16 PM
gunz4life2
Jan 23, 2007 01:13 AM
