Assembly on forged lq4
#22
What tranny converter flexplate combo are you going with? The crank looks like it came out of an early iron headed 6.0. Those cranks are longer (about .400") than the aluminum headed 6.0's. The aluminum headed 6.0's came with a spacer that bolts on the back of the crank where the flexplate goes, and the iron headed 6.0's were just longer without a bolt on spacer. If you are using a stock flexplate, stock 80e converter you will be fine. If you are going with an upgraded flexplate, they are thicker, and you will have to make your converter manufacturer aware of this so it will fit properly. It isnt a problem, just make sure you mention this if you are purchasing an aftermarket converter and flexplate.
#23
blown02408
Oct 1, 2015 01:06 AM
