ARP main studs or OE TTY
Old Dec 23, 2013 | 09:09 PM
Default ARP main studs or OE TTY
I am building a brand new never run OEM gm iron 2011 LY6 block into the engine in my sig for my TA.
If I were to install ARP main studs is it a install and go with no further work or do the main caps need to be fully torqued then have a machine shop check to see if the block needs to be line honed.
Old Dec 23, 2013 | 09:26 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I would have it checked before and after. With TTY and with the studs to see if they distort differently.
With out know were they are prior to the studs It's hard to say. If there already on the loose side it may need a honed with studs to bring it back in spec.
They may still be within spec with the studs but it's better to be safe then sorry.
Old Dec 23, 2013 | 10:06 PM
oakley6575's Avatar
Yea I would have the checked for sure. The studs usually clamp a lot better and need the hone.
Old Dec 23, 2013 | 10:53 PM
ragga da fragga da frick. May just put stockers in it not to have to mess with it. I had the machine shop check everything just to be sure block was in spec and with OEM bolts everything checked out. I just dont feel like waiting or hassle. OEM bolt's never seem to have problems may just roll with them. Thanks for help.
SS94S10
Jan 3, 2019 01:57 PM
AdaMax
May 16, 2016 11:35 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
