ARP Head Studs question
Old Jan 27, 2014 | 10:55 AM
ak2007r6's Avatar
Default ARP Head Studs question
So I still have a set of ARP Pro Series head studs from my 2011 6.2 build. My question is can these be used on my 2004 5.3 motor? I thought that the head stud kit was specific to the newer style heads but when I look up the part number (234-4317) according to Summit it's compatible with my 5.3
Anyone have any experience with this? Seems pretty obvious with the part number and everything matching up but I could have swore I remember hearing these would not work on my 5.3
Thanks in advance for info/help.
Old Jan 27, 2014 | 11:07 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
They MIGHT work on your 5.3, I've seen both possibilities on 2004 engine blocks. I thought we talked about this already?
Old Jan 27, 2014 | 11:08 AM
ak2007r6's Avatar
We did and you said they wouldn't but after looking at the part number you can see the confusion. Heck even the box says LS1 on it for them. Hence the question.
So there is no sure way to know without trying then?
Old Jan 27, 2014 | 11:16 AM
You will have to remove at least one head bolt to find out. And it's under the valve cover.
Old Jan 27, 2014 | 11:22 AM
ak2007r6's Avatar
LOL thanks for that info......
Old Jan 27, 2014 | 11:39 AM
Lol!
If #10 & 3 are the same length, then your stud kit will work. If one is longer than the other, then your stud kit will not work. The difference is the block, not the heads. Here's a pic of what I think you'll see.
Old Jan 27, 2014 | 12:00 PM
ak2007r6's Avatar
Lol!
Thank you sir!
Old Jan 27, 2014 | 02:15 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
whats the production date of the truck early 04 or late 04
Old Jan 27, 2014 | 02:26 PM
ak2007r6's Avatar
6/18/2004
Old Jan 27, 2014 | 02:30 PM
well its a mid year 04 so its a gamble they didn't start doing the same length bolts till later 04 so its a toss up what you have looks like your gonna have to just do what roger said
