arp head stud torque specs
Old Oct 21, 2008 | 08:34 PM
bad cutt's Avatar
Default arp head stud torque specs
I am replacing the head gaskets on my 5.3 this week. I have arp head studs and can't seem to remember the torque specs. thanks.
Old Oct 21, 2008 | 08:38 PM
Mangled03gmc's Avatar
Baltimore Whore
http://www.ls1howto.com/index.php?article=2 towards the bottom of the page youll see it
Or https://www.performancetrucks.net/fo...ecs+head+bolts
John
Old Oct 21, 2008 | 09:04 PM
SRT10KLLR's Avatar
Former Vendor
I just had my AFR 225 heads installed along with ARP studs and I think it was 25 ft/lbs for the shorter(8mm) and 75 for the longer(11mm). But it depends on weather you use their lube or 30 weight oil.
Old Oct 23, 2008 | 05:23 PM
bad cutt's Avatar
thanks for the links and info guys, but in the three links it refers to arp head bolts I am lloking for the spec on studs, if anyone has the specs for the head studs that would be great,. thanks
Old Oct 26, 2008 | 01:10 AM
WhiteRhino's Avatar
This was just on tech. It should help you out.
https://ls1tech.com/forums/showthread.php?t=870781
Old Oct 26, 2008 | 10:50 AM
bad cutt's Avatar
I called arp and the techline said 85 and 25 so that's what i did.
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
ChevyLee
Jul 10, 2015 10:56 PM
NuckenFuts
Jul 9, 2015 08:45 AM
