arp head stud install
Old Aug 21, 2010 | 06:39 PM
orange1500hd's Avatar
Default arp head stud install
i didn't know that the head bolts on gen III engines were TTY until now, gonna get some studs since i will be boosting anyways. i had to replace one head on the 6.0 i picked up but the other side is fine, when i put the studs in can i replace the good side one at a time or do i have to take that head off and put a new gasket on there also? just seeing if i can save some time/money. the engine only has 20k miles..
Old Aug 21, 2010 | 07:02 PM
Atomic's Avatar
I have a gauge for that
Not a good idea to reuse head gaskets....but people have done it. You can do one side at a time, but may as well do both at once
Old Aug 21, 2010 | 07:04 PM
Truckshop's Avatar
i would change the bolts one at a time on the side thats not messed up. its not the correct way but if it you could always do it by itself later.
Old Aug 21, 2010 | 07:07 PM
brent5631's Avatar
If the head is never pried up it might work. But get ready to swap it when it doesn't work.
Old Aug 21, 2010 | 07:38 PM
i guess il do both sides, just a head gasket il have to replace.
Old Aug 21, 2010 | 08:23 PM
budhayes3's Avatar
PT's Slowest Truck
I think that you'll be better off that way, plus, you can torque them sequentially properly, instead of one at a time, while the originals are still TTY'd in the block...
brent5631's Avatar
After thinking about it. I think you have to install the back most stud when you install the head. Put it in the hole then slide the head on.
Old Aug 21, 2010 | 09:17 PM
ok, thanks for help everyone
Old Aug 22, 2010 | 12:59 AM
budhayes3's Avatar
PT's Slowest Truck
Yes, there are a few studs in the rear that you have to do after the head is on, or the head won't slide on since the firewall is in the way...at least one that I'm aware of. Put all of the other studs in, slide the heads on, then screw in the remaining stud or two that creates clearance issues.
Old Aug 22, 2010 | 01:11 AM
ha, my engine is sitting on the stand right now so..
