Anyone running a kick out oil pan?
#21
How much hp loss is there from windage issues on a 1000hp motor?? To me it would have to be pretty substantial before I would put any type of money into it (assuming it would have to be custom and there is not one that bolts right up). I mean, your already making 1000 hp so I dont get why you would need the little bit more that a kickout would get you?? Maybe I am looking at this all wrong but I just dont get it.
#22
GM Performance Parts lists a circle track pan (part # 19243065) that is listed as being a 6 quart pan, but requiring a remote oil filter / adapter and as such should bring total capacity in around 8 quarts. It is said to be designed around typical rear steer GM chassis, but due to the length of the sump, I’m sure either the sump or chassis would have to be modified to fit a truck. It comes on their CT525 circle track LS3 crate motor.
#23
GFYS and STFU
The only hard data I've found from what I've read and researched are not for our LS motors so I can't answer that question specifically, but a properly set-up crankcase system on a big displacement N/A BBC or SBC that is built to spin to 7-8000 rpm's, it's been shown to gain 8% to 10% horsepower at the crank. So a 1000hp motor would gain between 80-100 hp in the set-up mentioned above. That is not just with a kick-out mind you, that is with lots of smaller details taken into measure to control windage, from tear-dropping the counter weights on the crank, to pulling inches of vacuum on the pan, etc...
I might ask this on tech and see if any of their track guys have done any testing on our LS motors. But from what I understand windage losses on motors in general are one of the major over-looked areas in improving engine efficiency which in turn makes more power.
#24
Well if it would be a 10% gain then I would say look into it. You could be the pioneer in the subject for trucks. Who knows, in 10 years maybe it will be a standard procedure and it will be in the "bolt-ons" thread lol.
#25
#26
Pat what's the c6 pan look like or what makes it different from our pans? The ZR1 pan is a dry sump I believe right, is the c6 dry or wet?
1LOW4x4, a kick out is an additional chamber that would be found on the passenger side of the pan. It reduces windage effect that a crank see's on a typical oil pan. When the crank rotates it slings oil in a clockwise direction, the kickout gives the oil a place to accumulate and drain back into the sump as apposed to being "churned" by the counterweights. The more oil mist/vapor/droplets that are suspended in the crankcase the more resistance it causes crank to have to fight through i.e. windage effect. A properly set-up crankcase can net a significant gain in hp as well as more efficient lubrication system.
Billy, while u haven't even considered a KO pan for a truck, some have.
Wow, didn't know asking about oil pans would hit such a nerve with you guys.
...I guess making a truck handle the twisties makes more sense than improving crankcase issues on high hp engines, and by issues I mean my last motor was blowing oil out the oil pan seal as well as the EVAC lines poping off while under boost, but maybe I'm just paranoid...
Just to clarify then, it's ok to put turbo's, S/C, nitrous on our trucks, make 1000 hp motors and break into the 9's but it's not OK to worry about the little things on the bottom end of the motor? And I don't see how having a truck makes any difference in how HP is made. Maybe I should go ask on tech...
There's nothing wrong with the truck pan for what most of us do with our trucks, It works fine and does it's job. But there is better out there. Same with intakes...there's nothing wrong with the truck intakes either but people are constantly swapping on different ones to see what's what. I'm just moving on to different parts of the motor. And since I had issues with my last set-up I'm researching what else is out there and what I can do. I'd like to be able to pull some vacuum on the crankcase with either a belt driven pump or something similar but I don't think it's realistic so I'm just trying to find alternatives and asking around. Just looking for information, not a flame job for asking questions.
Windage losses on a 1000hp motor can become pretty substantial, so I'm researching what to do before I drop the motor in.
#27
...It is probally un-likely that any one Is running a Pan Like what you are reffering to In a truck application. You will most likely have to modify the Front crossmember. The pan will most likely have to be custom made too...
Can It be done? YES
Will it fix a Blow by issue You had with your other motor? NO
Will a kick out prevent you from starving the motor? NO
Don't forget The oil filter housing pad Is built into the Driver side of the pan. so in order to kick out that way you will have to relocate the filter...
Just food for thought...
Can It be done? YES
..., the question I asked was relevant. I did not say I disagreed with you in principal, I am just wondering what your are trying to achieve. In my opinion, there is more to it than a different oil pan, I have owned, and seen plenty of high HP engines that did not require a special oil pan to achieve perfection. I hate to see people over complicate and over spend on what is a simple thing, but hey its your deal and your wallet.....go for it. I think you are barking up the wrong tree, but hey that's my .02.
I guess I will get back to "making my truck handle the twisties".
If you are not looking for input then don't ask for it.
Thanks Joseph, I think Moroso makes a kick out pan to fit our applications, not 100% sure though. I remember someone on here having one on their shortblock but forgot who it was, I wanna say dhpro but I could be wrong. Also the kick out is usually on the passenger side due to the crank's rotation. Most off the shelf kick out pan's that are on the market for LS engines have a notch in it because of the starter. I've heard some people relocate the starter to the driver's side but those who do that usually are also running a dry-sump system and don't have the filter in that location anyways.
So I guess the answer to my question was...no, nobody has tried running one then.
When doin tranny swap, I noticed wires for my low oil level sensor has some of sheathing cut into tho.
I think as does someone else I asked, could it just be from uncovering sensor? I saw this thread over last few days, but just now read it, so I'm gonna multiqoute like Billy (his record is 9 BTW).
Thanks 1Bear, this is the kinda of information I was hoping to learn. I don't know if I am gonna do this or want to do this, I started this thread to see if anyone HAS done this and looking to get feedback from them that's all.
marlboroman71818, u said: power gained shouldn't be a linear percentage. The amt. of power being taken away should be close to identical no matter how much horsepower it's loosing from windage, because the hp REQUIRED to displace oil is the same no matter how much power the engine makes. IE, the amount of oil that the crank moves at a certain rpm is the same if it is in a 200hp or 1000hp motor. Will it gain hp? Yes. Will it gain 80-100hp? It would not be accurate to the laws of physics to assume that the percentage will be linear. I hope this helps.
What do u do for a living?
#28
I applied that thinkin, so I thought my 500hp goal would save 40-50hp. Guess not, see below.
#29
lets see, ive worked at ..., heavy truck mechanic, parts person, service writer, ..., generator mechanic,..., SAR technician, college student, and the new job is field specialist for Chevron. Mostly though physics: mechanics and heat, and chemistry are my favorite subjects.
I knew u just didn't fall off the turnip truck. By what u posted to this thread about linear power & another thread or 2, I saw today.
#30
GFYS and STFU
Thinking about this, the power gained shouldnt be a linear percentage. The amount of power being taken away should be close to identical no matter how much horsepower it is loosing from the windage, because the hp REQUIRED to displace the oil is the same no matter how much power the engine makes. IE, the amount of oil that the crank moves at a certain rpm is the same if it is in a 200hp motor or 1000hp motor. Will it gain hp? Yes. Will it gain 80-100hp? It would not be accurate to the laws of physics to assume that the percentage will be linear. I hope this helps.
Some Windage losses are incured for reasons that are constant (which would support what your saying) and some reasons that are variable(which I'll explain later). Windage losses that are constant and do not change with motor operation would be the size and shape of the oil pan(volume), location of the windage tray (if supplied), type of sump(dry or wet), type of oil the motor runs(viscosity), the coating of the rotating assembly(There's a thread that callies just started concerning a new coating which helps shed oil dropplets), and the surface area and shape of the cranks(more on this later). If those were the only variables that effect windage losses I would agree that the losses would not be linear since those are constant in a specific engine regardless of what kind of power your making with it.
However losses that are variable and dependant on horsepower(and more importantly how it's produced) is engine RPM's, pressure and friction.
-As far as RPM's are concerned...windage losses are best described as frictional losses incurred between a moving part and the air and oil particles around it. The forumla for Horsepower as you know is (torque x rpm/5252). So by that definition the faster you spin that crank and rotating assembly (in order to make more horsepower) the higher the frictional loads will be on those parts and the more drag will result. As evidenced by the shity areodynamic properties of our trucks, the faster we make them go the exponentially harder it is for us to make them keep accelerating. The windage losses on a motor that spins at 4,000 rpm's are exponenially less than a motor that spins at 8,000 rpm's which would explain why the losses are not only linear but exponential the more horsepower you make.
-As far as pressure is concerned, the faster you spin an engine the greater amount of pressure waves are created not just by the rotating counter weights but by the pistons reciprocating in the cylinders. Each time one comes down on either the power stroke or the intake stroke that piston moves a volume of air into the crankcase. The piston on the opposite cycle will be create a void of that same volume of air and that pressure wave will move across the lower assembly causing turbulance, aggitating the oil particle's that are suspended in the crancase and the air around it. This effects all of the moving parts. Again, the faster you spin the engine to create more horsepower, the more churned up the crancase atmosphere is gonna become increaseing the windage losses seen by the engine.
-As far as friction is concerned, I mentioned in my last post that you referenced that "alot of smaller details were taken into measure to control windage, from tear-dropping the counter weights on the crank, to pulling inches of vacuum on the pan, etc..."
Once way to reduce friction is to reduce the surface area of the moving parts that are exposed to windage losses, in particular the counterweights. On a stock crank most of the counterweights are squared off and have flat surfaces. Crank's used in race motors have had the leading edges rounded and the trailing edges ground to a dull point, somewhat like a teardrop. Everyone knows that a ball has less surface area than a square of the same size, shaving those corners down reduces the amount of surface area therefore lessening the amount of drag on the crank. And that tear drop shape has also been well researched to cut though a volume in a much cleaner way. (Ships at sea nowadays are designed with a "bulbous bow" to reduce the low pressure area directly associated with a leading edge when run through a volume. I studied fluid dynamics in college as part of my engineering degree.)
That's why I think windage losses are exponential to the amount of horsepower that a motor makes. Not only because of the speed of the rotating assembly but the amount of surface area that is present in the crankcase. So a BBC V8 spinning 9,000 rpm's will have alot more windage losses than an Honda 4banger spinning to 9,000 rpm's because of the amount of surface area that the BBC crank, pistons, rods have in relation to the honda motor.
Again though, the data I came upon in relation to the 8-10% were drawn from BBC drag racing motors, I'm not sure how applicable that data is to our LS motors but the theories and principles still apply.
Hope all that made sense.
