Anyone make DI Heads?
Old Mar 5, 2010 | 10:42 AM
Spoolin's Avatar
GFYS and STFU
Default Anyone make DI Heads?
Has anyone heard or read about anyone that makes a set of Direct Injection heads for LS motors?
Old Mar 5, 2010 | 01:47 PM
ForcedTQ's Avatar
Spoolin, I've been thinking about this for a while now. I haven't heard of anyone doing this yet, but it would be quite awesome. I've been drawing up some ideas about incorporating ideas I've seen around for infinitely variable valve actuation technologies to incorporate in with a DI head that would bolt on to a LS based short block. I think if someone ever made it to production with a retrofit kit they'd do well to start it with a design compatible with the smallest bore size 3.78", then offer different valve / combustion chamber sizes after they got the 5.3 market to help pay for R&D cost.
Adding a custom tuned DI head with close to infinitely variable valve timing could have huge potential on a 5.3 I think. It would require a new/piggyback ECU (to control valve events/ DI high pressure pump, and injection timing) to integrate with the stock ECU, but then you could probably set it up to be tested and have a CARB certificate.
Old Mar 5, 2010 | 05:18 PM
Spoolin's Avatar
GFYS and STFU
I've done limited research on it and have yet to come up with anything. GM is starting to produce DI engines but as of now only in the smaller engines. I'm building a motor that will be N/A for now and eventually it will see boost, but I don't want to be limited in my compression ratio.
I haven't even heard a peep out of the big head companies either about designing a DI head so...
Old Mar 5, 2010 | 07:50 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
See your avatar....that is all
Old Mar 5, 2010 | 10:36 PM
Spoolin's Avatar
GFYS and STFU
I turned the power off prior to forking the socket!!
Oobray
Jun 13, 2022 03:38 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Three6GMC
Aug 3, 2015 07:53 PM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
