Any way to tell what rpm range your engine is most efficient in?(mpg talk)
Old 04-08-2007, 08:16 PM
Mr. Sandog's Avatar
Thanks, I knew we kept you around here for something.
Thanks.........I think.
Old 04-08-2007, 08:25 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
If your little saying holds true then it looks like 4.10s and 37s will be the ticket with a 1950 cruise rpm at 75mph. 4wd drifts on 37s ought to be fun, just hope I can fit em
Old 04-08-2007, 09:05 PM
Mr. Sandog's Avatar
Please tell me you're not going to try 4.10's in a 10-bolt with 37" tires...
Old 04-08-2007, 09:14 PM
1slow01Z71's Avatar
Nope I have a 14 bolt SF sitting in the garage with a detroit locker, arp stud kit, aftermarket alloy axles, and a t/a diff cover waiting to go in as soon as I get the engine running, come on now Im not that retard
Old 04-08-2007, 09:15 PM
COLDZ71's Avatar
He mentioned he was going with a 14 bolt
Old 04-08-2007, 09:17 PM
COLDZ71's Avatar
I guess I could let you answer your own questions
Old 04-08-2007, 09:42 PM
Mr. Sandog's Avatar
Excellente....of course it would help if I read the whole first post.
Old 04-08-2007, 10:16 PM
TurboGibbs's Avatar
The 418 will build the low end torque period, no matter the cam....to an extent of course. Get the tire size you want and drive what you've got. Log and tune and decide on gear last. With a couple months of driving and tuning to decide. Everything is different. Don't decide on gear now. Let it be a finishing touch when you are "done".
Old 04-08-2007, 10:23 PM
1slow01Z71's Avatar
Problem is, I have all the parts to rebuild the 14 bolt right now last thing to buy is the gears, so it would be nice to buy the gears, once, I can run it on the 10 bolt for sure and be easy on it but after its up and running thats the next mod is the rear. I also bought the front diff off turboberserker which has 4.10s in it so I would like to know if I could get away with that since r&r of the front diff isnt exactly fun. Thats why im trying to get some suggestions for where I should be so I dont have to "trial & error" it. The 14 bolt I have came with 4.10s that are in good shape so Im going to start off with the 4.1 ratio and see if I happy, main thing I was worried about was having to go with 4.56s.
Old 04-08-2007, 10:30 PM
TurboGibbs's Avatar
In that case just run the 4.10's for a couple months and take your time with the gear. Seriously, only time will tell on the "right" gear for you to be happy. The 4.10's will be close...If not right with the 418, 224 cam, and 37's.
Quick Reply: Any way to tell what rpm range your engine is most efficient in?(mpg talk)
