Any body building a 370?
Old Mar 11, 2014 | 04:30 PM
TURBHOE's Avatar
Default Any body building a 370?
I bought my pistons and rods assuming my block was going to be good to go with just a hone job. Well it's looking like it may have to go a little further than the clearances will allow for my pistons. Had I bought even a slight over bore piston I would have been good. That being said, If anybody has a good bore 6.0 that they just want to build to a 370 just because let me know. Id like to swap blocks with you.
I know this should be in the trade section but it made more sence to me to put it here.
Old Mar 17, 2014 | 08:50 AM
BigKID's Avatar
Have you contacted the piston manufacturer to see if they will swap out the pistons for you. Wiseco swapped out my 4.035 shelf pistons with a custom 4.040 piston when machine shop #1 overbored my block.
Old Mar 17, 2014 | 11:12 AM
TURBHOE's Avatar
i will but these were custom made already.
Old Mar 24, 2014 | 05:42 PM
TURBHOE's Avatar
.003 cleaned up the bore giving my pistons .007 clearance. Is this going to be too much? I'm at 10psi daily and right now 15psi on the high boost switch. May be more later on.
Old Mar 24, 2014 | 09:13 PM
BigKID's Avatar
That is the clearance mine had after machine shop #1. Based on my talks with a few experienced builders and advice from a couple other forums, I opted to have mine redone. What size pistons do you have now? Have you already had the machine work done?
Old Mar 25, 2014 | 03:50 AM
TURBHOE's Avatar
He was finishing the block up as far as I know yesterday.
Blackrat48
Aug 16, 2015 11:56 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Ammadien
Jul 22, 2015 08:50 PM
121
Jul 16, 2015 12:18 AM
ALynch
Jul 6, 2015 09:49 AM
