Another mild LQ4 build
Old Nov 7, 2016 | 01:27 PM
wretched73's Avatar
Default Another mild LQ4 build
I just picked up an LQ4 that I plan to rebuild over the winter and install this spring. I'm looking on advice on what cam to run and if anyone knows of a machine shop who can clean and mill the heads for me
2003 LQ4
317 heads
stock bottom end
Going into 2005 Silverado 4x4 ECSB
Currently 4l60E- might go 4l80E by spring
Stock converter
3.73 gears w/33" tires
Motor supposedly had a small knock in the bottom end, I never heard it run so I'm not sure if it was a knock or lifter noise. Either way I'm going to rebuild the bottom end with new bearings and new rings but reusing the rotating assembly.
I'd also like to put a small cam, mill heads, new lifters/springs/push rods.
Any advice on a cam? Truck is a DD, will be used to tow and won't be raced. I'm not interested in doing a converter or gears at this time.
Edit- Also, at the same time, I'll be adding 1 7/8" long tubes to 3" catted y pipe with 3" exhaust out the back
Old Nov 7, 2016 | 01:42 PM
turboal1's Avatar
Default cam
I would check with TSP for a cam and kit
Old Nov 8, 2016 | 09:51 AM
wretched73's Avatar
Thanks, I contacted them. I'll report back on what they recommend
Old Nov 8, 2016 | 10:33 PM
Drspencer's Avatar
5 Year Member
Where you located? Or did you wanna ship the heads..
Old Nov 9, 2016 | 07:38 AM
wretched73's Avatar
I'm in Central NJ. Not looking to ship the heads
Old Nov 9, 2016 | 08:12 AM
madmann26's Avatar
Let's start with,
What are your goals?
The "knock" you hear might be piston slap.
Old Nov 9, 2016 | 09:50 AM
wretched73's Avatar
My goals are very simple, more low and mid range power than the stock 6.0 would have. I don't have any numbers I want to meet. I just want a strong, reliable motor that will make it easier to tow and haul ****. I don't race it and I don't have any plans to do so.
I've recently moved so I will put considerably more highway miles than I did on the 5.3. The 5.3 has 193k miles of mostly backroads doing no more than 50mph. Now I'll end up doing more of an even split of highway 75-80mph and backroads (50 mph max).
The 33" tires will most likely stay for the foreseeable future but a gear change might happen in a year from now (probably 4.56s).
Thanks for your help and I hope that clears up what I'm looking to get out of the new motor.
You're right the knock could have been piston slap- I never heard it run so I can't say for sure. Are there any "tells" that might tell me it wasn't knock? Do the heads or valves show any particular wear from piston slap?
Old Nov 14, 2016 | 01:24 PM
wretched73's Avatar
Ok, so far I'm debating these two cams. Any comments on how they should work for me? Read a few good things about each one, not sure if the 228R is going to be too aggressive for a stock stall
Texas Speed 228R 228/228 .600"/.600"
Texas Speed 224R 224/224 .600"/.600"
Old Nov 14, 2016 | 08:40 PM
grey matter 04's Avatar
13 Second Truck Club
I ran the 224r in my old setup worked great .
6.0 bored.030 over with 243 heads and 224r cam made 396hp and 405 tq.
Was a good mild combo pulled a 22ft boat great.
Power came on early which I liked. I ran a 3200 stall with 390 gears
