Another Cam Q
Old 03-03-2009, 11:12 AM
snwmn984's Avatar
Default Another Cam Q
Alright, well started making a list the other day for a cam swap. How about some help choosing or directing me.
Here is a little what the truck gets used for: Daily Drive, We have two boats, 18' lund alaskan and a 24' larson international, Something where i don't loose low end, or even gain a little low end. Strong Mid range for highway driving. But i still want a fun cam. And will still yield decent mileage. I don't want to run a converter. I do currently have a 2000 stall in, but if the trans goes, i will be going back to a stock stall. I had a 2400 in the past and wasn't the most comfortable to tow with.
A few cams i have been looking at:
Comp 206/212 .513/.52 115
Comp 206/212 .515/.522 112
Vinci 080 210/218 .551/.551 116
Comp 212/216 .52/.524 115(says a 6.0l cam, but don't see why it won't work in a 5.3?)
Comp 212/218 .522/.529 114
VooDoo 212/218 .471/.507 116
Thunder Racing 214/220 .600/.523 115 LSA
Old 03-03-2009, 11:19 AM
white lightning SS's Avatar
The specs of that Vinci cam look good for what your asking IMO.
Old 03-03-2009, 11:26 AM
snwmn984's Avatar
Thats what i was thinking, and the one i like the most. Didn't know if the high lift would be a killer on the low end though.
Where you at in the motor city? I'm in Taylor.
Old 03-03-2009, 11:29 AM
Higher LSA and non radical duration will keep your low end. I had to do go with a less radical cam for towing purposes myself. I'm in Roseville. Work in Farmington Hills.
Last edited by white lightning SS; 03-03-2009 at 11:30 AM. Reason: forgot location.
Old 03-03-2009, 11:34 AM
snwmn984's Avatar
Ahh, ya i see!
Good deal, i'm a pipefitter out of detroit...laid off.
Old 03-03-2009, 11:43 AM
The job situation here is an absolute joke. I work at a GM dealer and never imagined it would get this bad. Nobody spending money + 100% commission paycheck =
Old 03-03-2009, 11:48 AM
snwmn984's Avatar
Ya, the auto industry here is embarrising. My dad works in warren at the tech center.
Old 03-03-2009, 09:18 PM
snwmn984's Avatar
Anyone else? I know there are plenty of gurus running around this place.
Old 03-04-2009, 06:51 AM
old motorhead's Avatar
I'd bet you'd be hard pressed to tell the difference between any of them. The 112 LSA cam might idle a little rougher and make a little more midrange tq. It would peak lower and fall off quicker. You could probably put the others in a bag, shake them up, pick one, and be OK. The problem you're going to come up against is that you might find someone who's had one of these cams, but you probably won't find anyone that's had more than one in the same setup. No real objective comparison.
Old 03-04-2009, 07:22 AM
PT's Slowest Truck
budhayes3's Avatar
For your needs I like the specs of the Vinci cam, although I can tell you from experience, the Comp 206/212 is a great daily driver, that's the cam I have on a 114. No higher stall verter needed, although it wouldn't hurt
Quick Reply: Another Cam Q
