This is about a torque build!
Old May 26, 2006 | 05:54 PM
  #21
Steve Bryant's Avatar
LS1 Tech Veteran
OK, as promised here are the cam specifications (see attached image). Note, the cam lobes are Comp 3340R (Intake) and 3341R (Exhaust). These lobes are set up for a Chevrolet Big Block engine, but were ground on an LS1 Cam Blank. If you went to about a 111 degree lobe center line (versus my 109) your idle quality would be silky smooth where mine has a hint of surging and your emissions would be a little better. However, you would loose a little low to mid-range torque and you might extend the power band upward two or three hundred RPM's.
You could reuse all of your stock components except I would change to the Comp 26915 Valve Springs and the 774 Spring Retainers and I would go to the 7955 Push Rods (they are slightly longer than stock to compensate for the smaller base circle on the cam and a lot stiffer than factory).
All my best,
Steve
Attached Thumbnails This is about a torque build!-torque-max-3-cam-specifications.jpg
Old May 28, 2006 | 11:42 AM
  #22
tahoe's Avatar
Hi,
Thanks for the info!
Would it be worth the expense to install LT headers, for my purpouse?
I have seen claims of 20-25 Hp/Tq for the LTīs.
I have searched to no avail for a dynochart on LTīs on a stock 5.3,
any oune know wher to find one?
Br//
Blue03sss
Mar 7, 2019 05:06 PM
zachman078
Sep 21, 2015 04:36 PM
Blackrat48
Aug 16, 2015 11:56 AM
USMCvet0311
Aug 14, 2015 10:28 PM
black00chev
Aug 12, 2015 01:56 PM
