918's
Originally Posted by DLH2006
on average how long do the 918s last?
mileage wise
mileage wise
small duration+high lift=hell on small springs
large duration+high lift=not easy on small springs
and of course your driving habits, also beating on it before the engine is up to operating temp will decrease life since the springs are fairly brittle until they get hot.
I wouldnt worry about going 20K on a 580ish mid 220 duration cam, then replace them, its just good preventative maintenance since breaking one can cost 10xs more than replacing springs and 2 hours of your time.
Originally Posted by Quik
i have 918s and rev as high as 7k a few times. my cam is the TSP TV2 which is 232/234 595/598 112 and i have over 7k in miles since may when i put this together.
its not always about lift its about lift and duration also, and not only that but about the type of lobes youre using
YES! He has over 11:1CR, 3800 stall, blah blah blah and he is having problems getting it to run how it "should" bigger is NOT always better. Look into something in the High 220s LOW 230s, ook what slowprocess ahs done on a small 224. Also depends on the size stall you are going to run and gear
yea im getting real close to it running where it has to be, another tune did wonders
Good deal, to my knowledge no one has done a max effort 6L build
now im hoping to run a 13something on my 20s in future
