90mm or 102mm TB.
Registered User
90mm or 102mm TB.
I was wondering if a 90mm or 102mm TB fit & give HP, Tq to a 5.3L with a stock intake manifold? Wich would be best to buy? It is for an 05 Z71
Alternator will not need to be moved. I suggest buying a BWD CP561 canister purge solenoid. Take your MAP sensor, silicone it up in the top front part of the intake and either drill a hole in your intake tube and get a heater hose fitting or go to AutoZone and get a Spectre air filter part number 3991.
I was looking in to doing this but realized the price wasn't worth the gains or "the loss of lowend", but I have cable TB so I would have had to get the x bar cross over, idk with the 05 electric tb if you will need the x bar/crossover.
