700+ cu in? Short question.
A buddies of mine has a 427 sbc that makes just under 650hp at the crank. It spins to 6400 and makes gobs of torque. This is in a '94 ext cab semi daily/weekend warrior. It is super dependable with minimal maintenace... getting less than 100 miles on a 15 gal fuel cell puts a damper on the road trips, though. Lol. I vote small block!
here is what you need if you are dreaming big. http://www.nelsonracingengines.com/p..._454lsx_tt.pdf
Also you said they will make diesel like torque. Well if they make the torque they have to make the power also seeing as how HP is a product of torque.
HP = TQ x RPM / 5252.
Im not saying that it would be smart to run an engine that big in a street car or that it would even last, but saying things about stuff and giving false information is not the best way to go about answering this guys question.
GFYS and STFU
So when every Promod car in the country is going to bigger and bigger motors you are saying they arnt gaining power. I know for a fact that our promods. When we went from 738's to the 840's have picked up 250hp and they will now rev way higher than before. The 738's made peak power at 7600 and by 8000 they were out of breath, now the 840's make peak power at 8800 rpm and continue to pull but we dont turn them any higher to keep the piston speed down. If the heads, cam, and intake manifold is designed correctly gaining rpm will not be a problem.
Additionally...
My whole point of what I originally posted is that the high stresses created by large pistons and long strokes may limit the maximum rpm's at which the engine can safely or efficiently operate. (hence my original point of diminishing returns).
True that to a point bigger can be better, but building 800+ cubic inch motor for the street will cost more and produce less than something a fraction of that size for a fraction of the cost.
