7.50 push rods in a 6.2
Old Oct 10, 2013 | 06:31 PM
ou812sm's Avatar
Default 7.50 push rods in a 6.2
I'm running a gt9 cam in a stock 6.2 and the installer said we need a 7.5 push rods is that common with cams with high lift
Old Oct 10, 2013 | 06:54 PM
Mangled03gmc's Avatar
Baltimore Whore
Why wouldn't the installer check the length with a tool?
Old Oct 10, 2013 | 07:10 PM
ou812sm's Avatar
He did I was just surprised when he told me that the 7.4 was not good the engine is stock except for the cam going in I'm also changing the rocker arms to comp cams new arc gold rocker arms it probably has more to do with the rocker arms
Old Oct 10, 2013 | 07:15 PM
GMCSIERRA5.3's Avatar
What cam are you gonna use?
Old Oct 10, 2013 | 07:36 PM
ou812sm's Avatar
Lingenfelter gt9 cam spec are 215/247 .629/.656 lsa 121
Old Oct 10, 2013 | 10:13 PM
Vortec350ss's Avatar
I'm surprised to see that length too, but if he checked you gotta believe that's what you need.
I'd also say it must be due to the comp rockers
Old Oct 22, 2013 | 04:13 PM
Chevymax's Avatar
Is your truck at high idle with that cam? If possible can you post a vid
Old Oct 22, 2013 | 05:11 PM
TXsilverado's Avatar
i'm running 7.900 lol.
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
