6.2L or iron 6.0L????????
Old Jun 20, 2012 | 07:57 PM
  #21
TXSZ66AVLANCHE's Avatar
I've seen a couple of your hurt engines in person...also know who your tuner is, question is Wtf? Something ain't right fo sho
Old Jun 20, 2012 | 07:59 PM
  #22
ak2007r6's Avatar
Any engine will cause some serious carnage if the tune is not right or get's out of wack. Still not positive why mine went lean but I am pretty sure had this happened to any boosted motor the results would have been pretty much the same.
I still have plenty of faith in the 6.2 and we will just be way cautious this time around to make sure it enters PE every single time we want it to.
I don't remember who said it but he pretty much summed it up. These motors have not changed much at all over the years but the brains that control them have.
Old Jun 20, 2012 | 08:13 PM
  #23
62nalide's Avatar
IDK man IDK good thing they are backing me up
Old Jun 20, 2012 | 08:17 PM
  #24
62nalide's Avatar
true so true
Old Jun 20, 2012 | 08:35 PM
  #25
black00chev's Avatar
Slowest turbo build ever!
I personally like an iron block. So my vote would be the 6.0L. Keep the stock crank and punch it out to a 370 and have fun! Would be a torque monster with a 76mm.
Old Jun 20, 2012 | 08:46 PM
  #26
Byrdman11's Avatar
6.0 or 6.2 with good parts would be fine. But if I wanted to push it to over 900hp I would go iron block to be safer. I'm not sure what the alum block would stand.
Old Jun 20, 2012 | 09:27 PM
  #27
stock48's Avatar
9 Second Truck Club
If given the choice I would go with a alum block 6.0L. The iron blocks are 100+ lbs heavier and not as great as everyone thinks.
Old Jun 20, 2012 | 09:49 PM
  #28
jrmchevyman's Avatar
Whichever way you go, boost the crap out of it lol.
Stock GM LS Engine - Big Bang Theory - Hot Rod Magazine
Get 2 magnum, powermaster, borg warner, or precision 76mm's and let her rip.
Old Jun 21, 2012 | 04:26 PM
  #29
rjwz28's Avatar
Man Motor club
You will be fine with a properly assembled and tuned 6.2-based engine. I don't see you having any problems as long as you follow those guidelines. Urban has had factory-based aluminum block builds well over 1000 hp for years (the heaviest hitters {1600hp+} with some 6-bolt and sleeving enhancements from ERL). As long as the build is well done, the internals are well-chosen, and the tune is spot-on, you will not be block-limited.
Old Jun 23, 2012 | 08:47 AM
  #30
Bodis22's Avatar
better solution, get the cheaper 4.8, 5.3 block and punch it to 383. You get your desired iron block and the displacement for the low end torque!
